| engine guys HELP please | |
palermocorey90 Expert
| Subject: engine guys HELP please Wed Oct 17, 2007 3:32 pm | |
97rivman Fanatic
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 3:37 pm | |
| theres 2 small holes behind the TB that allow coolant in, the gasket and the o-rings might be shot...its a relatively cheap fix...what kind of engine you working with? check out www.intense-racing.com | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 3:38 pm | |
| its a 95 series 1 SC well what im most upset about is this chit, i only work 22 hours a week if that and i dont make a alot of money and for this to go wrong its going to cost me some big bucks. cuz knowing my luck antifreeze went inside the engine and now im going to be screw. granted i dont know as much about engine as i do paint and body work, but i know that antifreeze going into the motor and SC isnt the best thing in the whole work | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 4:19 pm | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 5:28 pm | |
| First off, I'm not a MECHANIC.
Next... I don't think any serious damage would be caused by a small amount of coolant going thru the SC. Clean up/out as much as possible from the TB/intake areas. Replace your TB gaskets. Sorry I can't offer any more advice than that. | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 5:37 pm | |
| what could it be for it starting up then revving so high then dieing
BTW thanks for the help, if you could try to get others to help | |
TType_Riviera Fanatic
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 7:10 pm | |
| you probably have a vacumn leak somewheres... as for the coolant...i wouldnt wory too much,unless its in the oil...anti-freeze eats bearings...ive seen regular 3.8's blow intake gaskets..and were so bad it filled the cylinders,,an hydrolocked the engine...seal it back up with new gaskets..clean out what you can of the coolant....start it let it smoke out...an your good... | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 7:16 pm | |
| thats the problem, it will start up but then it wont idle and then it will die, or it will start and rev up pretty high even when im not touching the gas any idea on that | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 8:19 pm | |
| ok well can i get a listen of things i should go get or order | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 8:37 pm | |
| Since you can't drive it anyway, I would take the TB off right off the bat and see what that looks like. If the problem isn't apparent there, maybe intake. Either one could explain the high idling and dieing. Bad sealing => vac leak - high idle, coolant leak - accumulation of coolant into the intake path and engine dies. I would definitely suggest not starting it ever again until it's fixed. Good news is that the problem may not be expensive to fix if it's just gaskets/seals and fluid flushes.
just wondering - did you notice what the exhaust smoke looked like while it ran. I would expect if its idling that high and dieing right after, you should see some interesting stuff happening out the exhaust. | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 8:39 pm | |
| the exhaust was white, so i know it was antifreeze in there
BTW thank you some much for the help | |
| Subject: Re: engine guys HELP please Wed Oct 17, 2007 9:40 pm | |
| if the IAC valve is messed up it will rev up like that. make sure it is clean and not installed wrong. like stated b4, i would disassemble the TB and clean everything up, then reinstall it with a new gasket, making sure it is tight and sealed. good luck _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: engine guys HELP please Thu Oct 18, 2007 10:22 pm | |
| as long as there isnt any coolant in the oil pan....the engine is fine..just need to figure out the other issues!! | |
| Subject: Re: engine guys HELP please | |
