 Changing Out an ECM - 95 Riv
Fastfrankie
Changing Out an ECM - 95 Riv Empty
PostSubject: Changing Out an ECM - 95 Riv   Changing Out an ECM - 95 Riv EmptyTue Oct 23, 2007 11:39 am
I believe my aftermarket ECM is bad in my 95 Riviera 3800 due to it getting wet/damp from a leak in the dash area - and I have no spark.
A friend of mine works in a junkyard and he just got me one out of a 95 Riviera 3800 (same exact car) that was just brought in but was hit.
I plan on changing out/swapping ECM's. Do I need to switch PROM chips out or should I just pop the new ECM in with its current PROM and forget about it?
Any help would be appreciated!
Brad95Riv
Brad95Riv
PostSubject: Re: Changing Out an ECM - 95 Riv   Changing Out an ECM - 95 Riv EmptyTue Oct 23, 2007 4:25 pm
Use the PROM chip that is in your car right now. The junkyard car may have had some differences, so it's best to use what you have.
Fastfrankie
PostSubject: Re: Changing Out an ECM - 95 Riv   Changing Out an ECM - 95 Riv EmptyTue Oct 23, 2007 8:12 pm
I agree with you but was told by a mechanic if for any reason the PROM in the ECM that may be bad or was shorted out as a result of moisture etc. and I use that shorted out/ruined PROM in the replacement ECM, that could short out/ruin the replacement ECM.
Any truth to this?
» Changing wheel bearings
» Purchase of a new jersey - Karlsson number changing?
» Converting a Vari-Drive to a 5 Speed Manual
» HID Conversion Kit Install Instructions
» NHIAA makes big classification change
