 ello govna
GothicVash
Merit: 0
PostSubject: ello govna   Tue Oct 23, 2007 2:24 pm
ok so i was wondering if there is a way to disable the govener on my 95 riv. if its simple/cheap to do its worth it for me as i do eventually plan on swaping out to a built serries 2
Merit: -24
PostSubject: Re: ello govna   Tue Oct 23, 2007 2:37 pm
i dont think there is an easy way
Merit: 9
PostSubject: Re: ello govna   Tue Oct 23, 2007 2:39 pm
You can contact Ryan at Gmtuners.
http://www.gmtuners.com/
He will be able to burn a chip to remove the govenor. And any other changes you would like. His prices are also very fair.
Merit: 33
PostSubject: Re: ello govna   Tue Oct 23, 2007 3:07 pm
Just be sure you are running tires that are rated for whatever top speed you intend... I believe the speed limiter is there to account for the factory tires.
GothicVash
Merit: 0
PostSubject: Re: ello govna   Tue Oct 23, 2007 9:49 pm
yeah i dont have factory tires i got bridgestone or firestone something or others rated for like 140 i onkly rember the speed rateing and that there better then most for snow at the bridge/firestone shop
Merit: 61
PostSubject: Re: ello govna   Tue Oct 23, 2007 10:19 pm
Swap to series II and then use a tuner program to change it.
Merit: 172
PostSubject: Re: ello govna   Wed Oct 24, 2007 9:10 am
Be sure suspension parts are also fresh. These cars can be scary above 120 riding on stock parts.
- John R. White, Boston Globe
GothicVash
Merit: 0
PostSubject: Re: ello govna   Wed Oct 24, 2007 9:39 pm
yeah i was planing on swaping to a serries 2 eventually was just wondering if there was a quick cheap way of doing it for right now witch seams doable with the chip peoples stuff tis going in friday to get everything checked out so i know whats on its way out to replace and what needs imidate replaceing im leaking oil they think its the head gasket and i kow the belt and ac blower need to be replaced also
ello govna
» ello govna
» ello
» ello
» 'Ello Darlin's...
» ello ppl
