 Crank Position Sensor
Fastfrankie
Crank Position Sensor Empty
PostSubject: Crank Position Sensor   Crank Position Sensor EmptySat Oct 27, 2007 5:44 pm
Replacing the crank position sensor on my 1995 Riv 3800 supercharged. Is it true you need a tool for get the adjustment/gap correct on these engines that only GM has?
Anyone replaced a crank sensor on these engines? Any tricks once you are ready to bolt it in? Thanks
PostSubject: Re: Crank Position Sensor   Crank Position Sensor EmptySat Oct 27, 2007 6:05 pm
i replaced one on my 96 and the only tool i needed was a puller to remove the harmonic balencer. you're suposed to get a CASE learn after replacing it but most never do or need to. (you should get a code if you do need to).
the only tips i can give you are
1. you will need more force than an air gun can provide to loosen the crank bolt. so use a breaker bar, leverage, and bump the starter over until its loose.
2. dont use too much thread lock on the torque to yield bolt bonk
Crank Position Sensor Dsc_0110
Fastfrankie
PostSubject: Re: Crank Position Sensor   Crank Position Sensor EmptySat Oct 27, 2007 11:47 pm
I believe my crank sensor is bad. I have no spark and no injector pulse/12 volts at the harness.
My Snap On Scanner showed no rpm's when I cranked the engine over. That pretty much points to a bad crank sensor.
Anyone have a crank sensor go bad and if so, did you experience a no start and no fuel/12 volts to the injectors?
» RZR Problems
» Pick the best springbok in each position
» How to wire up a Low Oil Sensor.
» need help quick! Kohler Command wont crank.
» What is the most challenging position to play?
