Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17Post Count : 3922 Merit : 31
Subject: Re: Twin Charging Wed Jan 16, 2013 11:07 pm
Has anyone here done this? Twin charged their Riv? I imagine this would do the job, yeah? http://shop.zzperformance.com/store/p/188-ZZP-Z7-Turbo-Kit.aspx
T Riley Guru
Name : Travis Age : 33 Location : Minnesconsin Joined : 2007-02-08Post Count : 5127 Merit : 10
Subject: Re: Twin Charging Wed Jan 16, 2013 11:16 pm
thats not even a twincharged pic.
charlieRobinson Expert
Subject: Re: Twin Charging Wed Jan 16, 2013 11:18 pm
the pic came with the link. I am talking about the kit.
T Riley Guru
Subject: Re: Twin Charging Wed Jan 16, 2013 11:31 pm
no one has a turbo'd riv.. besides some dude in Florida i believe but its a tube chassis drag car thats fiberglass and uses an earlier model 3.8 with a turbo or 2.. theres vids all over youtube of it. that doesn't count though
Subject: Re: Twin Charging Wed Jan 16, 2013 11:44 pm
I am surprised no one has pushed it to this point yet.
T Riley Guru
Subject: Re: Twin Charging Wed Jan 16, 2013 11:51 pm
I had plans! but I learned that making the power in the 3800 platform was quite silly...
Subject: Re: Twin Charging Thu Jan 17, 2013 12:22 pm
T Riley Guru
Subject: Re: Twin Charging Thu Jan 17, 2013 11:01 pm
Just sold my regal tonight for some mad Profit though.. I have a soft spot for 3800's... I always will Now to find a car to flip with 5K bucks..
Subject: Re: Twin Charging Thu Jan 24, 2013 1:23 pm
Check out this build. What do you guys think about the intake port on the side of the headlight like this? I think it's SWEET. Not sure it could be pulled off on the Riv though.
simba510 Amateur
Name : SIMBA SMITH Age : 34 Location : OAKLAND C.A. Joined : 2013-01-22Post Count : 23 Merit : -1
Subject: Re: Twin Charging Thu Jan 24, 2013 6:42 pm
my question is how much minimum should i be looking to spend....because one does not simply make a plan with out some sort of budget awareness...
Subject: Re: Twin Charging Thu Jan 24, 2013 8:16 pm
$15k $5k for the Riv $5k for parts $5k for everything else
simba510 Amateur
Subject: Re: Twin Charging Thu Jan 24, 2013 8:22 pm
WHATS EVERYTHING ELSE BECAUSE I HAVE A RIV ALREADY AND WHERE WUD I GET THEM AND WHAT PARTS WOULD I NEED
Subject: Re: Twin Charging Thu Jan 24, 2013 8:27 pm
Do this:
simba510 Amateur
Subject: Re: Twin Charging Thu Jan 24, 2013 8:31 pm
WELL CAN YOU POINT ME IN THE RIGHT DIRECTION BECAUSE I DONT EVEN KNOW WHERE TO START LOOKING
Name : Derek Age : 51 Location : Reading, MA Joined : 2007-01-31Post Count : 7717 Merit : 109
Subject: Re: Twin Charging Thu Jan 24, 2013 9:41 pm
What's your budget and what do you think your goals are? What's the full current condition of your car?
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13Post Count : 18448 Merit : 251
Subject: Re: Twin Charging Thu Jan 24, 2013 10:48 pm
Looks like a good build, but intake is tacky. Here's a case where simpler isn't better. FWI does the same thing and isn't visible.
T Riley Guru
Subject: Re: Twin Charging Fri Jan 25, 2013 4:27 am
don't feed the troll
simba510 Amateur
Subject: Re: Twin Charging Fri Jan 25, 2013 6:25 pm
WHAT TROLL?
simba510 Amateur
Subject: Re: Twin Charging Fri Jan 25, 2013 6:26 pm
AND AS OF NOW I DONT REALLY HAVE A BUDGET BUT I WANT TO KNOW WHAT ALL I WOULD NEED TO GET SO I CAN MAKE ONE
Subject: Re: Twin Charging Wed Mar 13, 2013 7:37 pm
yall see this Regal? http://www.fullthrottlev6.com/forums/showthread.php?48867-Twin-Charged-Regal
highwaywarrior Fanatic
Name : daryl Age : 40 Location : chesapeake va Joined : 2012-06-09Post Count : 403 Merit : 2
Subject: Re: Twin Charging Wed Mar 13, 2013 8:02 pm
Yum, wonder how it feels
Subject: Re: Twin Charging Wed Mar 13, 2013 8:09 pm
THAT'S how you do it. Stock engine, mostly stock exhaust, 1.9 rockers, then twincharge it to run 12s. I like his style. Complex instsllation, simple idea.
Subject: Re: Twin Charging Thu Mar 14, 2013 7:59 am
You don't see this configuration very often. There's a lot of debate on whether or not the turbo intake should run into the blower or if it should integrate into the intake manifold after the blower.
Some say the supercharger becomes a restriction others say it does not. Some people say the dual set up is completely inefficient (because of heat output) compared to either just a blower or just a turbo. But then you see people who actually do it and they get great results.
I think it really comes down to how you transition between the supercharger and turbo in making boost. From what I've read, you want a smooth transition. instead of the supercharger disengaging and then then turbo starting to spool. You want the spool to start right when the supercharger is peaking and then transition over.
From what i've seen, everyone whos done this to the 3800 runs the turbo right through the blower with no problem.
