 P1406 EGR Valve Pintle?
96RIVMANN
96RIVMANN
P1406 EGR  Valve Pintle? Empty
PostSubject: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyMon Oct 29, 2007 10:18 pm
So I pulled a code from my 96' with 155K on it. It read P1406-EGR Valve Pintle. Anyone ever have this come up and if so how did you remedy it. I put in a different egr valve that I had lying around and the light still comes on. It might be another bad egr valve though. Is there a way to test it?
Sag
Sag
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyTue Oct 30, 2007 12:06 pm
Front or rear?
96RIVMANN
96RIVMANN
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyThu Nov 01, 2007 4:24 pm
What do you mean by front or rear?
Sag
Sag
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyThu Nov 01, 2007 5:02 pm
there is one on the rear valve cover in front and one in gaz tank
up front it put gaz fumes from tank in engine when dead, engine
tend to run lean one in rear to eqwalize tank pressure with atmospherical pressure(this one goes to the front building pressure then to the
engine at acceleration)The front one is easy fix but the rear one you'll
have to remove gaz pump from trunk then drop the tank (pain in the ass).Good luck
96RIVMANN
96RIVMANN
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyThu Nov 01, 2007 7:34 pm
Not sure what you are talking about. There is only one up by the rear valve cover on my 96. My factory repair manual mentions nothing about a EGR valve in the gas tank.
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyThu Nov 01, 2007 11:27 pm
He's probably thinking of EVAP canister.
TType_Riviera
TType_Riviera
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyThu Nov 01, 2007 11:46 pm
might have been the wrong egr valve.....just because it fits doesnt mean its the right one!
Sag
Sag
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyFri Nov 02, 2007 10:51 am
oops it was evap sorry
'96reese
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptySat Nov 03, 2007 4:10 pm
look up in the sky its a bird its a plane.......no its reese's mitchell on demand disk....but seriously though, i'll check the code out and email you the procedure to fix the lil problem....do you have a jumper wire and multimeter, cause you will need that to figure out what it is
'96reese
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptySat Nov 03, 2007 4:11 pm
real quick though to trouble shot the problem check all you vacum lines leading away from the throtle body...if any cracking replace those first to see if it fixed the problem
96RIVMANN
96RIVMANN
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyThu Nov 22, 2007 10:56 am
I did find that the rubber elbows that connect to the throttle body were cracked so I fixed them hoping it would take care of the problem but no luck. Still searching for a fix before I drop the $150 on a new egr.
Merit : 122
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyMon Feb 11, 2008 10:34 am
Did this end up getting fixed? I just had the same code pop up on my 95sc.
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyWed Mar 12, 2008 3:07 am
KillaKeninaRiv
KillaKeninaRiv
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyTue May 04, 2010 8:56 pm
I guess I just joined the EGR club! Mine popped up the other day and I went to AutoZone, and they told me it was the EGR valve. I went to one of the boneyards but they told me the valve was only found (for a 1997) on a 1997 Riviera NA and an Aurora. So now I have to hit the other yard because paying $163.99 at AutoZone isnt an option!
Name : Going Nowhere Fast
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyMon Dec 09, 2013 6:58 pm
Wtf man these codes why are they coming out all of a sudden,P1406,P135 what do these mean if I took it to the shop and had it to be checked O2 sensor it says it needs to be heated and the guy in the shop said I didnt need it.... egr has just been replaced for the reason it was broken
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyTue Dec 10, 2013 10:30 am
Maybe you have a bad ground or problem in the wiring harness. Closely inspect your wiring harness near the firewall connector for cracks and broken wires.
h20man
h20man
Merit : -2
PostSubject: Re: P1406 EGR Valve Pintle?   P1406 EGR  Valve Pintle? EmptyTue Dec 10, 2013 7:15 pm
I fixed my 1406 code with a new egr valve, that code will show up if the egr gasket is cracked too i think felpro makes them for 2$
» valve adjustments
» 16HP oppossed twin valve adjustment
» Removing Valve Retainers
» SUPER GLUE fixes valve stem
» Briggs and Stratton valve cover modification (No catch can or Drain hose required)
