 No Start - strange ignition problem
Sag
Sag
No Start - strange ignition problem Empty
PostSubject: No Start - strange ignition problem   No Start - strange ignition problem EmptyTue Oct 30, 2007 12:20 pm
My car refuse to start for two days now,i'v check everything fuel related even
cleaned injector at hand,the coils are ok(i have 9 spare ones anyway)
ignition module been changed wires check and recheck(for order they are new)i have injector pulse(it even flooded 2 times)new spark plug again
and again now everything have dryed i remarked that it only spark 2-3 times
and then no spark no mather how much i crank(but the injector works!)
so after checking fuses and relay i'm just more puzzled.......even 4
mechanics seems as lost as me.HELP please i miss my car and it's
becoming a hudge problem
Sag
Sag
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyTue Oct 30, 2007 1:46 pm
My next move gonna be checking all ecm fuses and relay cleaning
ecm ground then i'm gonna put myself in fetal position and cry,
if nothing still work of course lol. puzzled puzzled headbutt shoot
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyTue Oct 30, 2007 3:40 pm
i dont know if this could be it but plug wires
Sag
Sag
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyTue Oct 30, 2007 3:42 pm
About a month old and plugged correctly but tanks
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyTue Oct 30, 2007 5:14 pm
i cant remember correctly, does a bad CKP sensor cut fuel or spark?
how about a bad ground?
if it is only sparking a few times at first try and then will not spark any more. that sounds like a safety sensor gone bad. like passII key disabling startup b/c it thinks you have the wrong key.
btw you should post your rivs year and engine in your sig so we dont have to keep asking wink
thats my 2cents anyways. hope you get her fixed soon, i'd be going insane!
No Start - strange ignition problem Dsc_0110
Sag
Sag
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyThu Nov 01, 2007 10:10 am
HA ha a bad ground,the starter stop spark!!the icm,cam and crank
sensor ground to the body near fuse box rusted out.A metal screw
and were in buisness happy happy happy Tanks all
Sag
Sag
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyFri Nov 02, 2007 10:58 am
it's came back haunting me yesterday no fire 1/3 wit other module
no fire 1/6 i think my two icm both dead grrrrrrrrrrrrrrrrrr at least everything new it will end soon and crank seem ok headbutt
Sag
Sag
PostSubject: Re: No Start - strange ignition problem   No Start - strange ignition problem EmptyTue Nov 06, 2007 12:21 pm
ok so now there is devlopement (and a new post name)
after a humidity related problem that i'm no shure if it's now fine
after the car sat outside overnight it wont start properly(but ok when sat inside) no fire on some coils (icm ok) after a long fight (+-15 min) it usually start and code for misfire(oh surprise)then run fine for the day,when say fine it's really fine(as long as it don't sat for 6-7 h)There is dielectric grease nerly everywhere and i think still take humidity but dunno from where it's becomming really a pain in the a$$ any idea shoud be really apreciated me and 4 mechanics r going crazy help
» Tecumseh HH120 Won't Start
» 18hp briggs twin cylinder opposed power problems. PLEASE HELP!!!
» Strange chunk of metal, has NO effect on detector, what is it?
» New info on MSD ignition for 09 Teryx
» Brisbane Track Class 11/02/11 Start Lists
