 serptine belt problems
heyzelchi
serptine belt problems Empty
PostSubject: serptine belt problems   serptine belt problems EmptyFri Nov 02, 2007 7:52 am
Ok Last week my serptine belt came off I went to precision tune an they reapir edit by putting on an new alternator belt tensioner and new belt tensioner. but today when I driving to work the serptine belt came off again any one have info on what the problem is
PostSubject: Re: serptine belt problems   serptine belt problems EmptyFri Nov 02, 2007 9:26 am
Did they put on a new belt, too? Usually belts slip off because they're installed with part of the belt not on the pulley(s), or one of the ribbed idler/tensioner pulleys could be broken. If the tensioner is bad, that could also cause it.
Sag
Sag
PostSubject: Re: serptine belt problems   serptine belt problems EmptyFri Nov 02, 2007 11:00 am
or an incorect belt
PostSubject: Re: serptine belt problems   serptine belt problems EmptyFri Nov 02, 2007 11:24 am
or if the belt gets too wet. like with a coolant leak headbutt
serptine belt problems Dsc_0110
NO 4 EVR
NO 4 EVR
PostSubject: Re: serptine belt problems   serptine belt problems EmptySat Nov 03, 2007 4:37 am
Or s/c oil bonk
(bad seal caused bad leak)
» Teryx Belt Recall
» XP1000 problems
» Chain in place of belt.
» Prototype of new combo belt harness for Minelab GPX's
» RZR Wheel Hub Problems?
