| | Differences in Superchargers | |
| Author | Message |
Name: Aaron Age: 34 Location: C-bus, Ohio Joined: 2007-01-13 Post Count: 14467 Merit: 172
 | Subject: Differences in Superchargers Thu Nov 08, 2007 12:10 pm | |
| I found this graph a couple years ago, and found it interesting. Yes, I know there's a turbo in there, but it's a type of supercharger. The various types of superchargers are correctly named below:  Note how closely the Roots blower's torque curve follows boost. Also, the power advantage of the turbo is very clear on this graph, as well as its peaky delivery. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
"I think that in any racing engine, the nearer you are to disintegrating, in general the better its performance will be." - Keith Duckworth, Cosworth Engineering
3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco F/Rsway bars • ES links/bushings • GM strut brace • Enkei 18" EV5s • Dunlop DZ101 tires F-body calipers • EBC bluestuff/Hawk HP plus • SS lines • slotted discs • ATE superblue fluid • DHP tuned • Aeroforce • Hidden Hitch
turtleman Addict
Name: Codith Age: 24 Location: Villa Park, IL Joined: 2007-02-08 Post Count: 2655 Merit: 89
 | Subject: Re: Differences in Superchargers Thu Nov 08, 2007 12:32 pm | |
| It's shocking to see a turbo yields more low initial torque than a centrifugal blower and also strange to see that the turbo levels off. I figured it would continue on up.. more so than the centrifugal |
deekster_caddy Guru
Name: Derek Age: 40 Location: Reading, MA Joined: 2007-01-31 Post Count: 6091 Merit: 83
 | Subject: Re: Differences in Superchargers Thu Nov 08, 2007 3:09 pm | |
| turbo depends a lot on other factors. Another reason I like belt-driven superchargers - the consistency is hard to beat. The low end torque is where it's at anyway. I prefer a grunty low end motor to a high revving one. More fuel efficient and less rotating speed = less chance of breakage  |
 | Subject: Re: Differences in Superchargers Thu Nov 08, 2007 4:48 pm | |
| The engines used in these tests must've been monsters. On the dyno, my car's max wheel torque was about where the centrifugal blower's starts at 2500 RPM!
A lot of people think turbos have superior fuel efficiency compared to roots blowers. Their reasoning might be that turbos are more "efficient" power adders, that blowers suck power from the engine, and that turbos don't use much fuel at cruising speeds. But they don't consider that an efficient power adder doesn't mean a fuel efficient one, blowers require almost no power at cruising RPMs, and they often forget about our boost bypass, which effectively turns the motor from FI into 8.5:1 N/A. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
Mr.Riviera Aficionado
Name: Matthew Age: 25 Location: Florida Joined: 2007-01-17 Post Count: 4008 Merit: 82
 | Subject: Re: Differences in Superchargers Thu Nov 08, 2007 8:46 pm | |
| Yeah, I got tired of that pretty fast. PowrTuner to the rescue! Of course, if I ever want to chug, I just put it into cruise and it's back to the old way. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
TType_Riviera Member
Name: Rob Age: 29 Location: ohio Joined: 2007-03-05 Post Count: 422 Merit: 0
 | Subject: Re: Differences in Superchargers Thu Nov 08, 2007 9:52 pm | |
| ofcourse with an effective tuning solution...during regualar driving you can have the ecu lean out the mixture to get optimum mileage.
I have never seen exactly how efficient the centrifugal style was on paper...and i always wondered why the mustang guys used them... i guess though you pretty much have the efficiency of a turbo,with superior intercooling vs a regular roots/screw.. |
turtleman Addict
 | Subject: Re: Differences in Superchargers Thu Nov 08, 2007 10:28 pm | |
| | TType_Riviera wrote: | I have never seen exactly how efficient the centrifugal style was on paper...and i always wondered why the mustang guys used them... i guess though you pretty much have the efficiency of a turbo,with superior intercooling vs a regular roots/screw.. |
the thunderbird super coupes have intercooled M90s on them. but they are older and make less power. I hoped that using that style housing on the L67 might be possible to utilize air to air intercooling but I see no way to do it |
 | Subject: Re: Differences in Superchargers Fri Nov 09, 2007 8:16 am | |
| quote: "ofcourse with an effective tuning solution...during regualar driving you can have the ecu lean out the mixture to get optimum mileage."
I've never tried this, as I thought the PCM would just compensate. But I have read about some advancing the timing really far to get 45+ mpg.
quote: "i guess though you pretty much have the efficiency of a turbo,with superior intercooling vs a regular roots/screw.."
Centrifugals also sound really cool! Better than Whipple, imo.
quote: "I hoped that using that style housing on the L67 might be possible to utilize air to air intercooling but I see no way to do it"
Believe it or not, it's possible to do air-to-air intercooling on the L67 with the factory blower. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
Karma Fanatic
Name: Andrew Age: 27 Location: Ontario, Canada Joined: 2008-01-14 Post Count: 1383 Merit: 87
 | Subject: Sweet article on supercharging Tue Jan 13, 2009 10:05 am | |
| Sweet article on supercharging:
http://www.jagweb.com/aj6eng/supercharging_article.html _________________  |
 | Subject: Re: Differences in Superchargers Tue Jan 13, 2009 10:24 am | |
| Very good read, Andrew! One of the things to keep in mind - the inefficiency of a roots blower has one small advantage: it helps in keeping the torque curve flat. If it were more efficient, like a turbo, you would get more power up top, but the roots design encourages that strong low-end grunt, albeit less horsepower output overall. Twin screw is my personal favorite. Perfect power delivery, imo! _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
Karma Fanatic
 | Subject: Re: Differences in Superchargers Tue Jan 13, 2009 10:30 am | |
| and another article on flow for the m62, basic, but a good read nonetheless: http://www.aerospaceboy.com/384/analysis.htm
and more: http://www.corvetteactioncenter.com/specs/c6/2009/zr1/blower.html
and a very helpful pic: http://www.corvetteactioncenter.com/specs/c6/2009/zr1/images/64266.gif _________________  |
hotrod58 Trainee
Name: Josh Age: 23 Location: McPherson Kansas Joined: 2008-12-11 Post Count: 22 Merit: 0
 | Subject: Re: Differences in Superchargers Tue Jan 13, 2009 3:05 pm | |
| so what kind of superchargers does our Riviera have factory? |
 | Subject: Re: Differences in Superchargers Tue Jan 13, 2009 3:08 pm | |
| Roots blower, manufactured by Eaton:
http://www.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Superchargers/M90/index.htm
Detail drawing (this is different from the older Gen III used on the Riviera):
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_167919.jpg _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
Karma Fanatic
 | Subject: Re: Differences in Superchargers Tue Jan 13, 2009 3:19 pm | |
| | hotrod58 wrote: | | so what kind of superchargers does our Riviera have factory? |
and the m62 in the riveria(95 year, series one engine) is a Gen 3 M62 which saw epoxy coated rotors and a 2.8" pulley. Not to be confused with the previous Gen M62's that did not have coated rotors and as a result needed a smaller pulley(2.55") to make the same boost. Visually you can tell the difference in the veins that go doen the sides of the SC casing. If they go all the way down the sides, its an older one. If they stop at the top rounds on the top of the SC, its a Gen 3 M62._________________  |
