 Series 1 aftermarket transmission pan???
blackbart95
blackbart95
Series 1 aftermarket transmission pan??? Empty
PostSubject: Series 1 aftermarket transmission pan???   Series 1 aftermarket transmission pan??? EmptyFri Nov 09, 2007 8:22 am
Does anyone know of an aftermarket transmission pand to fit my '95? looking for pan with drain plug. More capacity and something made of cast aluminum would be a plus. If a pan is not available, what about a weld-in drain plug kit?
PostSubject: Re: Series 1 aftermarket transmission pan???   Series 1 aftermarket transmission pan??? EmptyFri Nov 09, 2007 8:40 am
i dont know what tranny you have in the 95 but zzp has this.
http://www.zzperformance.com/grand_prix/products1.php?id=547&catid=105
larger capacity will not help you out much.(i think it is already like 16qts) but a trans cooler will add life and takes a few more qts to make it full.
also i believe our pans are aluminum already.
Series 1 aftermarket transmission pan??? Dsc_0110
PostSubject: Re: Series 1 aftermarket transmission pan???   Series 1 aftermarket transmission pan??? EmptyFri Nov 09, 2007 8:52 am
Your 95 has a 4T60E
From the link Mr.Riviera posted
"Fits GM cars and mini-vans with the 4T65E,/4T60E transmission."
PostSubject: Re: Series 1 aftermarket transmission pan???   Series 1 aftermarket transmission pan??? EmptyFri Nov 09, 2007 9:21 am
Cool, I'm going to get one for my mini-van! lmfao
blackbart95
blackbart95
PostSubject: Re: Series 1 aftermarket transmission pan???   Series 1 aftermarket transmission pan??? EmptyFri Nov 09, 2007 10:30 am
Ouch. $190 is a lot to add a tranny drain plug to my car, which is my main goal. I guess I will go the weld-on drain plug route to my existing pan. I'm not sure on later models, but may pan appears to be stamped steel or possibly aluminum. I guess I will take a magnet with me while I am under it changing the oil this weekend.
PostSubject: Re: Series 1 aftermarket transmission pan???   Series 1 aftermarket transmission pan??? EmptyFri Nov 09, 2007 11:40 am
We looked at this awhile back. I think most of us agree it's not worth the price. Link:
http://rivperformance.editboard.com/series-ii-engine-transmission-f4/zzp-aluminum-pan-t1239.htm
» Peerless 700 transmission questions
» Transmission & gear-case fill, drain and oil
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
