 asap S/C help
zetabird
asap S/C help Empty
PostSubject: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 3:32 pm
i need help i was driving the riv i only got a block with the heat on then i sme;;ed the supercharger oil first thought was oh shit, i opend the hood and heard a whining like bad bearings so i got the car hope pulled the belt off and theres alittle rotating play withs i think is the coupler but im sure the beirings are shot ive alredy lookied into rebuilding the snout but im worried about the leacking oil it dosent seem to be comeing from the pully if i cant get this fixed soon im in deep crap my other cars 1 hour awhay and stored
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 3:58 pm
How low was the oil? Have you tried putting more oil in and seeing if it improves? Where is it leaking from?
zetabird
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 4:32 pm
its odd the oils fine i just checked it and nowits seaming that the smell wasent the sc oil but its smoking really bad from the rear head i might have over filled it when i changed the oil though i think that would cause that wouldent it and i thing the sqeeiling is the idler below the supercharger
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 4:51 pm
It's hard to overfill. It would spill out before you put the plug back in. Maybe you spilled some on top of the engine??
zetabird
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 4:56 pm
no i mean i think i overfilled the normal oil lol we had a few extra qts areound when i was working on it and my dad got them all mixe3d up i used the partial to pre fill the oil filter and i thin he to...anyway im sure its the idler now
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 5:22 pm
Probably the idler pulley, then. The blower usually won't fail if it has oil. Well, at least it's an easy fix!
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 5:24 pm
so where does the oil come up to on the dipstick?
which filter are you using?
using a stock filter in a 96+ riv you should put in 4.5qts of oil.
if you are using the upgraded fitler (pf52) like most of us, you will need 5qts of oil.
is the car parked on pavement? can you verify it is leaking motor oil and not something else?
asap S/C help Dsc_0110
zetabird
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 6:08 pm
im using the stock 95 size bosh oil filter the computers showed me at work (autozone) and it said 5 quarts so it is over filled its about half a quart past the fill mark and the smell is motor oil but its not leacking and i t runs fine
TType_Riviera
TType_Riviera
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 7:04 pm
bad valve cover gasket?
Sag
Sag
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 8:35 pm
goes out from pcv ?
zetabird
asap S/C help Empty
PostSubject: Re: asap S/C help   asap S/C help EmptyMon Nov 12, 2007 11:03 pm
i was thinking the pcv i wouldent think a valve cover gasket could fail like that
asap S/C help Empty
asap S/C help
» Space available in Junior Rimrocker: E-mail ASAP.
» Suriamas Fully Furnished Unit for Rent (ASAP)
» LeMaitre runs 9.95 in Euro Team Champs
» WTB SENKO STYLE BAITS ASAP!!
» F/S Shimano Ci4 1000f ASAP $130
