 Sensor range help
Sag
Sag
Sensor range help Empty
PostSubject: Sensor range help   Sensor range help EmptyMon Nov 12, 2007 8:00 pm
I really need the crank sensor and the cam sensor specs and range
as fast as anyone can answer please i must test em and can't find anywhere
the specs help please headbutt
Fastfrankie
PostSubject: Re: Sensor range help   Sensor range help EmptyMon Nov 12, 2007 8:52 pm
I just replaced my crank sensor in my 95 S/C Riveira. If the car is cranking with no start/spark and no fuel that is your problem. $30 at the local Advanced Auto and had it replaced in less than 45 minutes...
From what I am told, the crank sensor is a Hall-Effect type and cannot be tested in any way, shape or form.
I used my Snap On MT2500 scanner and wasn't picking up any rpm's as I cranked it over with the key - that points to a bad crank sensor.
FYI, the old sensor looked about a year or two old....looked new but was made in China....enough said!
Sag
Sag
PostSubject: Re: Sensor range help   Sensor range help EmptyMon Nov 12, 2007 9:32 pm
so if it spark strangely and flood if the icm is new and the ground
redone coud it be the cam sensor insted of crank??so it fires incorectly, i'm just more confused.........and the tach works fine
when it starts.
Fastfrankie
PostSubject: Re: Sensor range help   Sensor range help EmptyMon Nov 12, 2007 11:23 pm
Well if you are getting spark and have a new ECM, maybe the cam sensor is causing the misfiring. Sounds like a cam sensor but I am not positive.
Have you priced a new cam sensor - if it is cheap enough, it may be shotgunning the part, but if it is under $50 and you can do it yourself, it may be an alternative.
Or get someone to scan the computer...
Merit : 64
PostSubject: Re: Sensor range help   Sensor range help EmptyMon Nov 12, 2007 11:46 pm
parts in Canada are really expensive. It's robbery now that the cdn $ is worth more than the USD. GM list in the US is approximately gm dealer COST in Canada.
Sag, if you need genuine gm parts, contact me and I'll set you up with Dal. GM cost (us) + 10% + shipping. You need to get a few parts in order for it to be really worth it with the shipping.
Sag
Sag
PostSubject: Re: Sensor range help   Sensor range help EmptyWed Nov 14, 2007 2:21 pm
Tanks i've found a cam sensor at 60$ and a crank at 30$ can't wait
for delivery.
Sag
Sag
PostSubject: Re: Sensor range help   Sensor range help EmptyTue Nov 20, 2007 3:03 pm
yeah riv is running and running fine finally get rid of thoses
ignition troubles but don't know witch it was anyway i don't care.
tanks for your help
Sensor range help
» Rangertell Long range Detector Back on EBay
» whites gmt out gold detecting southern cross area. mt rankin to parkers range
» Driving Range / Coffeeshop
» How to wire up a Low Oil Sensor.
» Range on green at turb club
