| camshaft location? | |
etosino2009 Enthusiast
Name : Evan Age : 33 Location : columbus, ohio Joined : 2007-08-27 Post Count : 220 Merit : 0
| Subject: camshaft location? Wed Nov 21, 2007 11:48 am | |
| Ok i have been tinking about getting a camshaft for some time maybe this year for christmas. But i have some questins that are holding me back. I plan to have it get installed but if it sounds easy enough i might do it myself but where exactly is the camshaft located in the engine? and if i have it installed will it be costly with a lot of labor? and lastly what exactly do you have to do to install it? need help please before i order the part. thanks | |
| Subject: Re: camshaft location? Wed Nov 21, 2007 12:04 pm | |
| Read this. Should give you a pretty good idea:
http://74.57.209.83:9000/caminstall.htm
It starts off, "Welcome to one of the biggest nightmares you're going to get yourself involved in."
Not saying you can't do it, but it was more than I wanted to get involved in, and I've been a back yard mechanic for almost 15 years. If you pay someone, they'll want $600-$800 just for the labor. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: camshaft location? Wed Nov 21, 2007 12:26 pm | |
| perfect. but will it be okay in my series I cuz i noticed on zz perfomance it said gm 3800 96 and up | |
| Subject: Re: camshaft location? Wed Nov 21, 2007 1:18 pm | |
| acutally ill just get one from the series I site | |
| Subject: Re: camshaft location? Wed Nov 21, 2007 1:26 pm | |
| Good luck, Even. If you can, take some pictures of each step. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: camshaft location? Wed Nov 21, 2007 1:48 pm | |
| A cam install is not a simple task. Unless you are used to, and comfortable with major engine repairs, I'd recommend paying a professional who knows what they are doing. jmho. | |
97rivman Fanatic
| Subject: Re: camshaft location? Wed Nov 21, 2007 2:13 pm | |
| ummm.......have u heard of intense??? | |
1998rivman Amateur
| Subject: Re: camshaft location? Wed Nov 21, 2007 7:12 pm | |
| I second the Intense hint.
I'm not real familiar with the Series I motors, but am I correct in reading that you are running a 2.5" pulley with nothing more than mufflers and an intake? If I tried that on my 98, the blast radius would be pretty large.!! Is there that much of a difference in the SCs on the 95 motor? | |
| Subject: Re: camshaft location? Wed Nov 21, 2007 8:37 pm | |
| Yes, the M62 blower needs to spin faster to make the same level of boost. 2.85" is stock SC pulley diameter. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: camshaft location? Fri Nov 23, 2007 7:39 pm | |
| hey guys thanks for the advice but im going to have to have some one install it for me, which i havent had that much work with engines so ill just leave it to the pros. | |
| Subject: Re: camshaft location? | |
