 Need a replacement heated seat element
Need a replacement heated seat element Empty
PostSubject: Need a replacement heated seat element   Need a replacement heated seat element EmptyWed Nov 21, 2007 8:57 pm
My drivers heated seat doesn't work. The switch lits up lo and hi when depressed but the seat doesn't get warm. I guess I need a replacement heated seat element. I looked at Ed Morad's site but saw nothing there. Does anyone have any experience in this area? scratch
PostSubject: Re: Need a replacement heated seat element   Need a replacement heated seat element EmptyWed Nov 21, 2007 9:21 pm
Does it "click"?
PostSubject: Re: Need a replacement heated seat element   Need a replacement heated seat element EmptyThu Nov 22, 2007 3:53 pm
It clicks when the button is turned on and off....
PostSubject: Re: Need a replacement heated seat element   Need a replacement heated seat element EmptyFri Nov 23, 2007 10:12 pm
Probably need a new heating element. I'd think they should be common. I saw once where some guy actually tore apart his seat and found the part of the element with the break, and then soldered it back together. Not sure if you are up to this, but might be worth looking at if you can get the unit out.
PostSubject: Re: Need a replacement heated seat element   Need a replacement heated seat element EmptySat Nov 24, 2007 7:23 am
Mine just started doing the same thing. If you don't see it on Ed's site contact him directly. He doesn't list everything he has.
» Driver's seat occasional "click" = seat replacement
» RZR Aftermarket Seats
» Fish Cat 4 Replacement Seats
» wanted -- van swivel seat
» Commander rear seat and cage.
