 FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side
Go to page : 1, 2, 3, 4, 5, 6, 7, 8  Next
¤DoughBoy¤
¤DoughBoy¤
FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side Empty
PostSubject: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyTue Mar 27, 2007 11:35 pm
Solving the warm/cold air issue requires access to the actuator mechanisms and vent doors located under the dash. Continue reading for info on fixing this problem. For a more detailed write-up on accessing the HVAC assembly, see this link: http://rivperformance.editboard.com/t2500-write-up-hvac-assembly#27279
____________
Original post:
Well today in Indiana it was like 80 degrees........so i decided to turn my ac on......it got cold on the passenger side but on my side it was hot as hell........why is that? and is it a big problem and is it going to cost alot.........
HELP!
Blowin95
Blowin95
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyWed Mar 28, 2007 1:56 am
Check underneath the black plastic shroud by your feet. You will see whats called a vent door actuator. It has a green and white sticker on it and is located close to the center console about 12 inches south of the gas pedal. Cycle your AC and watch and see if the actuator moves at all. If it doesn't, there is your problem. You can find them at a junkyard or get raped at a store, your choice. Hope this helps.
http://myspace.com/rumblinriv
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyWed Mar 28, 2007 12:02 pm
Thanks I will check it out!
Merit : 93
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySun Apr 08, 2007 4:33 am
Email Ed Morad, he had one for me. If the search function on regalgs.org is working you can google for my thread. I took lots of pics of the repair process. Not a writeup but it might help.
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySun Apr 08, 2007 3:45 pm
thanks!
I'm going to need my ac when it gets hot out........
Merit : 93
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySun Apr 08, 2007 6:49 pm
Yeah I know the end of the year is savage without AC. You go anywhere without it and you arrive wet and sticky.
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySun Apr 08, 2007 7:00 pm
I had the same problem on the passenger side, found the actuator, took it apart and got it working.
GothicVash
PostSubject: FAQ: Hot air on drivers side, freezing on passenger side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyFri Nov 09, 2007 12:36 pm
ok on my 95 the heat only works on the drivers side and when its on the passenger side is pumping out cold air like outside temp (high 30's low 40's) witch kinda pisses me off i cant get my car to warm up just to pump ambiant air in and half is warm for a lil then cold just wondering if anyone has any ideas oh and i just got the ac condenser (?) replaced cuz it wasnt working right and tearing up my belt
robertwolf86
robertwolf86
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyFri Nov 09, 2007 7:36 pm
i dont no how its poss to have belt problems b/c of the condenser? i would check the t-stat, and then the heater. then unhock the lines under the hood for the heating and hock a hose up to it and flush it out.
Fastfrankie
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyFri Nov 09, 2007 8:20 pm
I am having the same exact problem! Heat pumps out the driver side floor and the driver side half of the defrost vents for the windshield. The passenger side gets regular air/cool blowing and so does the passenger side of the defrost vents. Really wierd.
I replaced the thermostat today just for the hell of it. Still no heat on the passenger side. Can someone offer some advice. It has nothing to do with the heater core being plugged for sure.
I am wondering if there is a blend door or if that passenger side control button on the dash heat/ac controls or on the passenger side door has anything to do with it. Wondering if it can be bypassed...
Anyone that knows for sure??
dennycrane
dennycrane
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyFri Nov 09, 2007 8:30 pm
There is a blend door motor behind the glove box that causes that. You can take it off and manually turn it to let hot air come through til you get a replacement.
dennycrane
dennycrane
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyFri Nov 09, 2007 9:00 pm
You'll have to remove your glove box, remove a couple screws that hold two large computer modules and let them lay on the floor. In the red circle area is where the motor is located. After you remove it , the white plastic rod sticking out will let you move it manually til you get a replacement. This is on a 95 model.
FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side Rivpq4
Fastfrankie
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyFri Nov 09, 2007 10:29 pm
Denny,
Thanks alot....exactly what I needed!!! Also, I don't seem to be getting any warm air through the vents on the dash panel. Wonder if another door is closed or a motor is shot. Is there a fuse for the heater door motors? My heat and blower work fine; just seems that a door or two may not be functioning. Thanks alot man!
GothicVash
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySat Nov 10, 2007 1:45 am
it was attached to the belt could be the belt was just shot also but i know my condesner or whatever ac thing that is on the belt was shot everytime i turned it on then off it sounded like a dyeing cat got sucked into the supercharger balls first
ChiTownRiv
PostSubject: hot & cold - Its 2 cold for this   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySat Nov 24, 2007 9:03 am
if anyone is online i have a problem my 1995 buick riviera is blowing out hot heat on the drivers side and cold air on the passenger side is this a easy fix has someone seen this b4 let me know please gripe
TType_Riviera
TType_Riviera
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySat Nov 24, 2007 10:14 am
mixxer door servo..if you pull the glove compartment out you can see it....easy fix,but you will want to find a junk yard one...dealer wants over 200 bucks for a new one.
ChiTownRiv
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySat Nov 24, 2007 11:39 am
thanks man i found it it says on another post long as u turn it it will stay like that til u get a new one its kinda cold to go to the junk yard so imma wait it out
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySat Nov 24, 2007 12:03 pm
I was able to take the servo apart and fix mine, the motor was stuck.
Merit : 93
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySat Nov 24, 2007 2:40 pm
Mine was on the driver's side, got a replacement from Ed Morad for $20.
okiedrifter
okiedrifter
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyTue Dec 11, 2007 3:26 pm
so if mine is blowing AC on the drivers side and heat on the passenger side, would the servo activate the compressor? i have it unplugged, but natrally direct air from outside is cold as hell! so help me out
http://www.myspace.com/okie_drifter
ohdevn469
ohdevn469
PostSubject: Hot air on drivers side, freeze out the passenger   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyMon Jan 21, 2008 6:47 am
Even when the weather was warm, heat, defrost and auto air on the passenger side of the car is ice cold. Ive checked all the fuses, I don't know what else to check. Please help defrost my friends!
BillBoost37
Merit : 25
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyMon Jan 21, 2008 7:30 am
You should have a second air mix actuator. One for each side. Pull your glove box and try to see if it's visible and moving.
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyMon Jan 21, 2008 9:51 am
Kathi, your post was merged to this thread. Check dennycrane's instruction above. Good luck!
GothicVash
PostSubject: Re: FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptyMon Jan 21, 2008 11:17 am
how do i take the glove box out
Mikel
PostSubject: 1997 Riviera Climate control trouble   FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side EmptySun Jul 12, 2009 4:59 pm
Hello,
Last week I bought a 1997 Riviera SC. Love the car, but when I first got it, the driver side vents would blow warmer air than those in the passenger side (I didn't touch the passenger side controller). The lighting of the panel got very dim at times, but would be bright every now and then.
Now all I get is hot air coming out of the vents, with cooler air in the driver's side (it's 80F outside).
I've been doing some reading on this board and looks like bad solder joints in the control module would be the likely culprit. Before I start taking things apart, any suggestions?
Thanks,
Mikel
Page 1 of 8Go to page : 1, 2, 3, 4, 5, 6, 7, 8  Next
» Disabling Seatbelt Chime
» 5-a Side Team/11 a side team
» cold hands, warm feet
» Anyone got a Drivers Side Pro Armor door for RZR-S?
» Need Rear Drivers Side Axle with CV Joints -- 2005 Rhino
