 down pipe questions
4 posters
down pipe questions Empty
PostSubject: down pipe questions   down pipe questions EmptyTue Nov 27, 2007 9:25 am
im looking to get a ZZP down pipe for my series 1 riv will it work on my car . hears the link
http://www.zzperformance.com/grand_prix/products1.php?id=551&catid=110
will that work on a series 1, i think it should puzzled
PostSubject: Re: down pipe questions   down pipe questions EmptyTue Nov 27, 2007 12:56 pm
BUMP
PostSubject: Re: down pipe questions   down pipe questions EmptyWed Nov 28, 2007 8:18 am
Bump this dang
PostSubject: Re: down pipe questions   down pipe questions EmptyWed Nov 28, 2007 8:31 am
i dont think any of us have seen one on a series 1, so we cant give you a definite answer either way.
i know it will need to be welded in like on my 96 b/c we dont have a bracket to conect the dp to the cat.
what you may want to do, is look up the part # for the 95 and 96+ riv downpipe and see if they match. that would tell you for sure if the zzp will work.
down pipe questions Dsc_0110
PostSubject: Re: down pipe questions   down pipe questions EmptyWed Nov 28, 2007 8:34 am
thanks for the help matt
PostSubject: Re: down pipe questions   down pipe questions EmptyWed Nov 28, 2007 8:38 am
Didn't someone here get a downpipe from hogan performance that was for a H-body bonneville?
PostSubject: Re: down pipe questions   down pipe questions EmptyWed Nov 28, 2007 9:17 am
Yes, but it's for 97-03 models. It is a flanged bolt-in DP, not weld.
PostSubject: Re: down pipe questions   down pipe questions EmptyWed Nov 28, 2007 10:55 am
i have no problem with welding i have a mig and tig welding degree, i have a welder i just wasnt sure if they will work or fit on my car
down pipe questions
» FAQ: Down Pipe Questions (Series I SC)
» Dimensions of SLP flex pipe and down pipe
» Weird piece of plastic, grommett?, found in heater pipe
» 3" down pipe and 3" straight pipe in place of the
» FWI pipe
