| need advice for next set of mods | |
+4oldsman105 1998 Riv Mr.Riviera etosino2009 8 posters |
etosino2009 Enthusiast
Name : Evan Age : 33 Location : columbus, ohio Joined : 2007-08-27 Post Count : 220 Merit : 0
| Subject: need advice for next set of mods Mon Nov 26, 2007 10:57 pm | |
| ok i have to admit the series I isn't that fast as i would like it to be even with a CAI, 2.5 pulley, resonator delete, and performance mufflers. so i have noticed some kr issues when accelerating so my big question what is the next best set of mods to do for my car. 104 or 103 plugs? should i do any more work underneath the car like a cat delete? install the cam first? what parts will be best to cool my engine down? please help im really confused on what my next set of mods should be. | |
| Subject: Re: need advice for next set of mods Mon Nov 26, 2007 11:12 pm | |
| a cat delete will not yield much power. if you are running a smaller pulley then you should already have the 104 plugs installed. 103's may be overkill unless you really race it all the time. what are you using to monitor kr? whats the peak? how much boost are you peaking at with the 2.5 on the series 1?
a cam or rockers are an option to add hp and reduce kr, but you really need to be able to tune it to get the full potential and hp. you could also P&P the TB and blower. i dont know if any vendors will do it for the series 1's. if you do decide to p&p then you need to work on the internals some to open up the air flow inside the engine. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: need advice for next set of mods Mon Nov 26, 2007 11:25 pm | |
| Yes, go with the 104's. I also suspect your front exhaust manifold is as bad as the S II front manifold. See if you can find someone to port yours, or get a spare to port. Do it yourself if you feel like giving porting a try. Exhaust flow on the front bank is likely very poor. Rockers are a good mod to move more air thru the engine, and an easier install than a cam. | |
| Subject: Re: need advice for next set of mods Mon Nov 26, 2007 11:27 pm | |
| - etosino2009 wrote:
- ............ what parts will be best to cool my engine down? ....
A 180 thermostat, and lowering your cooling fan's turn-on settings. Don't know about the fan settings on a Series I though. | |
| Subject: Re: need advice for next set of mods Tue Nov 27, 2007 3:51 pm | |
| you could also P&P the TB and blower. so what is P&P i dont really understand. but also im going to get a scanner b/c i have no idea what kind of kr problems im haveing but i can defintley feel it when i WOT. also what do you guys mean when porting my exhausts manifold? srry guys i don't know much | |
| Subject: Re: need advice for next set of mods Tue Nov 27, 2007 4:06 pm | |
| P&P is "port and polish".
Porting is cleaning up and opening up an intake or exhaust port, or supercharger, usually by grinding away excess metal, so that there is less flow restriction. The OEM front exhaust manifold is ugly.... I should have pics I can post. | |
| Subject: Re: need advice for next set of mods Tue Nov 27, 2007 4:12 pm | |
| This pic shows the blockage pretty well. The opening should be a fully open circle to match the head ports. These are crap from the factory. But there's also a big limit on what porting the exh manifold will do for you, since the main body of the manifold is also waaaay too small for the 3 tubes dumping into it. | |
oldsman105 Junkie
| Subject: Re: need advice for next set of mods Tue Nov 27, 2007 5:45 pm | |
| Interesting, thanks for posting this. I have not seen Series I manifolds before. | |
| Subject: Re: need advice for next set of mods Tue Nov 27, 2007 9:31 pm | |
| hey guys thanks for all the advice but i guess what i should do is def go with the 104 plugs to prevent the kr issues i have and then maybe a 180 thermostat. but as for the exhausts i guess ill try taking it to midas and have some custom work done or porting the intakes, then ill maybe order the rockers. | |
palermocorey90 Expert
| Subject: Re: need advice for next set of mods Wed Nov 28, 2007 5:11 pm | |
| if ur gonna do that u should get MSD wire as well i got them for my riv, im not sure how good they work but they look nice, i will tell u how they work when i get the riv running
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D32789&N=700+4294892415+4294840137+4294864973+115&autoview=sku
thats the ones i got there for a GTP but they fit great with some extra, very easy to install cough | |
| Subject: Re: need advice for next set of mods Wed Nov 28, 2007 7:45 pm | |
| 180 t-stat and 104s should have been done before the pulley drop. that why they are supporting mods. hopefuly you havent done any damage since you say you can actualy feel the KR.
heat leads to knock on FI engines _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: need advice for next set of mods Wed Nov 28, 2007 7:58 pm | |
| - palermocorey90 wrote:
- if ur gonna do that u should get MSD wire as well i got them for my riv, im not sure how good they work but they look nice, i will tell u how they work when i get the riv running
thats the ones i got there for a GTP but they fit great with some extra, very easy to install cough Well i just had mine replaced not too long ago but are they perfomance ones or better than stock? But to the kr issues the engine seems to be running fine its only when i go WOT is when i can feel it, where it dosent accelerat smoothly. | |
| Subject: Re: need advice for next set of mods Wed Nov 28, 2007 9:00 pm | |
| im honestly not to sure just yet but with the size of the wires it cant hurt thats for sure | |
Jason Aficionado
| Subject: Re: need advice for next set of mods Wed Nov 28, 2007 9:20 pm | |
| don't buy into the aftermarket spark plug wire hype. Buy whichever ones you like best. I go with the cheapest ones (not the jobber specials... you know what I mean).
MSD isn't really better or worse than their competitors. I have some on my roadmaster, but it's because they were 60$ for the set instead of 158 for the delcos (crazy, eh?)
the only wires that can legitimately do what they claim -bettter EFI and RFI suppression- are magnecores. | |
BillBoost37 Junkie
| Subject: Re: need advice for next set of mods Thu Nov 29, 2007 6:46 am | |
| Larger plug wires haven't been proven to add any performance. They are typically the same size core with more insulation surrounding it. We can take an example from the S2 performance companies...they all run stock wires and stock coils.
The changes GM made from S1 to S2 were substantial. The S1 does have potential though. Oldsman mentioned the manifolds are tubular and close to a header in their flowing ability. The intake manifold can be ported to notice some gains. I have personally ported two or three and there is enough room for improvement to warrant pulling the manifold. Don't worry about a perfect gasket match unless you plan on matching the heads or at least chamfering the edge to help the transition.
Now.. here's the hard part. Like the S2 the S1 could benefit from tuning and it's a lot harder. There are some guys out there that do this type of thing. I believe Ryan from Sinisterperformance is one of the main guys. If you are flowing more air, then you need to ensure the ecu is aware of how much fuel to add.
I personally ran my car a little lean when adding a ported TB w/o any tuning. Porting a TB is tricky because it allows more air to enter, however the maf isn't skewed for the added air. Therefore the ecu believes the airflow has not increased and does not add more fuel. I learned quickly by watching my O2's and fuel trims.
Rockers will help, a cam would be custom at the moment. Another place to get a bit more out of your S1 is in the transmission. The car was programmed with nice soft shifts. A shift kit will help firm things up and transmit that power to the ground. | |
| Subject: Re: need advice for next set of mods Thu Nov 29, 2007 8:52 am | |
| Thanks for the useful Series I info, Bill! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: need advice for next set of mods Thu Nov 29, 2007 11:10 pm | |
| hey thanks bill, my plugs are new so i guess ill just leave those alone. but it's intresting how you said that i need to watch ecu and how much fuel it adds. would it be better if i did this to reset the computer so it re-learns my driving habits and how much fuel it shoud enter? | |
BillBoost37 Junkie
| Subject: Re: need advice for next set of mods Fri Nov 30, 2007 6:30 am | |
| Actually that would be the best way. However it is not the optimum way. It will start by running you on defaults and then start adding fueling etc based on O2's and the tables it has to work with.
Recently a friend sent me the bin (programming) file for a 93 S1 SC bonneville. Having worked with the S2 tables in HP Tuners it amazed me how few tables and modifiying ability the S1 ecu/pcm's have. While this file was a 93 and basically one of the beginning/learning years vs your 95 which would have much more programming. It really showed the differences and why the newer pcms can react better and quicker.to various conditions.
The way I would approach it would be to talk to a tuner that can program a chip for you. Then scan the parameters they request to get a custom tune that has modified tables for your specific needs. | |
| Subject: Re: need advice for next set of mods Sat Dec 01, 2007 10:11 am | |
| hey man thanks for the info i think i might take it to intense racing here in columbus since their specialty is 3800 series. | |
BillBoost37 Junkie
| Subject: Re: need advice for next set of mods Sat Dec 01, 2007 10:41 pm | |
| INTENSE may not be able to help much. Their specialty is 3800 Series II's. Although it wouldn't hurt to say hi to a great bunch of guys. Tell Todd I said "hi". Is it wrong when I know their # from memory? Oh yeah..nearly every part on my car came from Plain City OH. | |
| Subject: Re: need advice for next set of mods | |
