 Write-Up: Installing Boost Gauge
Go to page : Previous  1, 2, 3 ... 9, 10, 11, 12, 13  Next
VJD2
VJD2
Write-Up: Installing Boost Gauge - Page 10 Empty
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri May 14, 2010 3:34 pm
That sure would have been a nice easy way to hook it up instead of the other location but its not the end of the world. I'll be doing mine in the next week I hope. Just have to get some t fittings and such.
GreenSupreme
PostSubject: Boost source   Write-Up: Installing Boost Gauge - Page 10 EmptyThu Jun 23, 2011 2:46 pm
I'm installing a boost gauge, where is the best place to tap into for a boost source?
GreenMonster
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyThu Jun 23, 2011 3:00 pm
^ yea, thats me, could not find a write up for this when I searched, disregard.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyThu Jun 23, 2011 3:04 pm
I tapped into one of the black plastic lines in front of the firewall. That ends up going to a T connector right under the snout of the supercharger.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Jan 13, 2012 12:19 am
Recently I've been considering a good location for my Aeroforce Interceptor gauge. I thought about the door vents, A-pillar, lower console, steering column, and a pod on top of the dash. I prefer the locations where I can see the gauge and keep my eyes on the road, and also want to be able to reach the buttons on the gauge easily. I like what turtle did on page 2 of this thread, so will be creating a similar pod that hopefully looks semi-stock. Here's a photo chop of how the gauge will be seen from the driver seat:
Write-Up: Installing Boost Gauge - Page 10 AeroforceDash
The gauge will sit in a bullet-shaped pod sunk in to the column, angled slightly upward. I took a few minutes to model the pod in CAD. I'm going to use this for cutting a foam pattern on CNC lathe:
Write-Up: Installing Boost Gauge - Page 10 Aero3
Cross section:
Write-Up: Installing Boost Gauge - Page 10 Aero4
Write-Up: Installing Boost Gauge - Page 10 Aero1
Cross section:
Write-Up: Installing Boost Gauge - Page 10 Aero2
They way it's shown, the pod looks like it's protruding into the column panel, but it would actually be sanded flat and affixed to the panel (no cuts in OEM plastic), or I might build a custom piece using an extra column panel. This way the gauge cable could be routed through the steering column.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Jan 20, 2012 5:22 pm
Made some progress on the gauge pod. It got shorter and the shape is more elliptical. I added a recess to the underside to allow an adhesive mount option. Not sure yet if I want to do this or drill holes in my column panel. I sent the 3D file out to be turned, next step will be fitting the part to the column.
Write-Up: Installing Boost Gauge - Page 10 Aero7
Write-Up: Installing Boost Gauge - Page 10 Aero6
Write-Up: Installing Boost Gauge - Page 10 Aero5
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptySun Feb 05, 2012 10:55 pm
Received the pod from the model shop last week. Today I sanded the flat in the bottom and applied 2 coats of filler primer. I'm thinking of gluing the pod to the column with epoxy, routing the wires out the back and down around the left side.
Write-Up: Installing Boost Gauge - Page 10 IMG_9150
Write-Up: Installing Boost Gauge - Page 10 IMG_9151
Write-Up: Installing Boost Gauge - Page 10 IMG_9156
Write-Up: Installing Boost Gauge - Page 10 IMG_9158
Write-Up: Installing Boost Gauge - Page 10 IMG_9163
Merit : 122
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Feb 06, 2012 9:28 am
Pretty cool looking. Should look like it belongs.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Feb 06, 2012 9:51 am
Thanks. I could've made it look more OEM by removing the upper column cover and building in the pod, repainting the entire part for a molded look, but if you've ever removed the upper cover before, you know how much work is involved. I just couldn't see doing it for a gauge pod. This way should look acceptable, and more importantly the location will still be as functional.
rk0ehn
rk0ehn
Name : Christian Rolf Köhn
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Feb 06, 2012 1:46 pm
Very nice design indeed happy nice job and I bet it will look awesome!
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyWed Feb 08, 2012 4:05 pm
Very interseting. Can't wait to see the finished product.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptySat Mar 17, 2012 8:49 pm
Finally got around to painting. Used an airbrush with color-matched Valspar latex from Lowe's. Cost $3.
Write-Up: Installing Boost Gauge - Page 10 605CE29F-orig
Mounted the pod to the column with epoxy. So far, it seems plenty strong.
Write-Up: Installing Boost Gauge - Page 10 70263009-orig
Write-Up: Installing Boost Gauge - Page 10 3C487646-orig
Write-Up: Installing Boost Gauge - Page 10 78D22564-orig
Routed the wires through the gap.
Write-Up: Installing Boost Gauge - Page 10 A454159C-orig
First test run!
Write-Up: Installing Boost Gauge - Page 10 5427D869-orig
Merit : 133
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptySat Mar 17, 2012 10:00 pm
I almost don't believe it's AA's car from the gas level..
Looks good though. and you can still see 0-40mph range on the speedo without moving your head unlike my pod.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Mar 19, 2012 9:34 am
That looks pretty good.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Mar 19, 2012 9:57 am
Thanks. Here's a daytime shot with car on and fuel level corrected!
Write-Up: Installing Boost Gauge - Page 10 646D6E00-orig
ghost88
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Mar 19, 2012 9:58 am
what kind of led's are you using for your gauges?
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyMon Mar 19, 2012 10:11 pm
Just the recommended OEM lamps, no LEDs.
Decided to do something about the green color, to make it more closely match the interior. I found some thin blue filter sheet at the local hobby store. A big sheet is $4.50, enough to make quite a few colored discs to insert behind the bezel ring. Tried 3 discs and found it hardly made any difference. Then tried 7, then tried 9!
Write-Up: Installing Boost Gauge - Page 10 57A3865E-orig
Using 9 discs, and bumping the dimmer setting up to "3" on the Aeroforce, I got a pretty good result. Only problem: the entire face looked very blue during the day, so printed out a black mask sheet to hide most of the face, so only the display area shows through.
Here's the before:
Here's the after:
Write-Up: Installing Boost Gauge - Page 10 BlueFace2
Lost a bit of contrast, but it's readable in the car. May need to remove one or two sheets after trying in the daylight.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyTue Mar 20, 2012 12:08 am
Looks great! Nice fit n finish. happy
Rod.G
Rod.G
PostSubject: Boost   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Apr 20, 2012 11:00 am
How's it going? Got a question...in regards to getting a boost reading, what line would I hook a boost gauge to? Not yet interested in a permanent install right now. I know I'm not getting the standard 7-9 psi. but I did want to know exactly what I'm gettin right now. Can anyone help?
Merit : 122
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Apr 20, 2012 11:12 am
Page 5 of this thread has a pic for you.
Merit : 111
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Apr 20, 2012 2:54 pm
Below the supercharger snout is a vacuum tee with 2 vacuum lines. The back one goes across the rear valve cover. Tee into that line.
Merit : 122
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Apr 20, 2012 3:01 pm
But not if you have the series 1 sc with the m62. In that case use the spot that is in the page 5 of this thread.
Merit : 111
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyFri Apr 20, 2012 3:23 pm
Absolutely right. I didn't check, and Rod didn't put his year Riviera in a signature.
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptySat Apr 21, 2012 2:07 pm
Now fixed, thanks Rod!
BKRIV
BKRIV
PostSubject: Re: Write-Up: Installing Boost Gauge   Write-Up: Installing Boost Gauge - Page 10 EmptyWed Apr 25, 2012 1:24 pm
I have been waiting to see a boost gauge installation in the the cd holder location, so far all I have been able to find is window pillar, door air vent, steering column and ashtray... has anyone done this? I dont like to be the first especially where there are cheap little plastic clips involved.
Page 10 of 13Go to page : Previous  1, 2, 3 ... 9, 10, 11, 12, 13  Next
» volt gauge question
» Water Temp Gauge
» Fan w/ Temp Gauge
