| Write-Up: Installing Boost Gauge | |
+73RidzRiv 1997riv bigdave bmcd9179 stan joshuadalegrimes charlieRobinson Fromano matt270avian Johnny5 al_roethlisberger BKRIV Rod.G ghost88 rk0ehn J. Chris Davis GreenMonster GreenSupreme VJD2 7901mark Snowdog Its a car part now GMFreak8 brmcm15 Hometown Hero L67 Ryan from Ohio LARRY70GS 96Super robotennis61 texasfan010 woggy Rickw Fuzzy rivboy 97rivsc lyonsperformance 1wickedninja SuperRiv07 gliderguy agood1 Karma Chicken deekster_caddy albertj Supercharged blackbart95 99 Riviera 99 IBx1 palermocorey90 mr.19982tone Jack the R 98riv RIVhorsepwr RivMan okiedrifter jimmyriv AA 97rivman RhinoFLA urbsnspices dreww SpaceBar NO 4 EVR Jason TType_Riviera turtleman pwmin jax95riv Mr.Riviera oldsman105 1998 Riv T Riley 77 posters |
Sir Psycho Sexy Junkie
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 8:51 pm | |
| May be covered in here, but has anyone spliced into the cluster dimmer wire so their boost gauge lights up the same as the rest of the gauges? I feel like it shouldn't be hard, I just need to know what wire to splice into.
I've read some control dim by varying resistance to ground, and some by varying voltage on positive side.
If anyone could help me out that would be greatly appreciated! | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 9:56 pm | |
| I spliced mine into the lights in the door panel since I put my gauge in the vent that's right next to them. It lights up and dims with the LEDs that are on when the headlights are on. | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 10:04 pm | |
| Would you say the level of illumination is close to that of the dash? Does it dim with the dash when you spin the dimmer knob thing? | |
matt270avian Expert
| Subject: Re: Write-Up: Installing Boost Gauge Thu May 07, 2015 10:30 pm | |
| It dims with it, and it's not noticeably brighter or dimmer than the rest of the lights. | |
jbird Fanatic
Name : Jeff Location : Cleveland area Joined : 2013-11-11 Post Count : 364 Merit : 6
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 8:22 am | |
| depending where you are locating the gauge the ash tray light may be a good option to tap into.
Jbird | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 9:15 am | |
| Good call! I forgot all those things dim too. | |
charlieRobinson Expert
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 1:06 pm | |
| Why do you need boost gauge if you are installing tablet and running torque? Kind of redundant? | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 1:21 pm | |
| I've had it laying around for a while, and I think it looks kind of cool. And I'm kind of curious to see what torque reads vs what the gauge reads. | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 2:21 pm | |
| I'd take ACTUAL boost over "calculated" any day.... | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 2:33 pm | |
| - Abaddon wrote:
- I'd take ACTUAL boost over "calculated" any day....
Kinda my thought. How do scan gauges and stuff even calculate boost? | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri May 08, 2015 2:41 pm | |
| It's all based off of the MAP sensor....a few other sensors are in the equation, but the MAP is the only one that reads BARO. | |
| Subject: Re: Write-Up: Installing Boost Gauge Wed Aug 24, 2022 8:16 am | |
| Question on another Buick board. I know how to connect a boost gauge to the Series 2 M90 equipped SC3800, but what about the 1995 Series 1 M62? Is it the same hard vacuum line over the rear valve cover? The one off the SC snout vacuum tee? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
th3fr4nchi5e Addict
| Subject: Re: Write-Up: Installing Boost Gauge Wed Aug 24, 2022 10:43 pm | |
| Subject: Re: Write-Up: Installing Boost Gauge | |
