 Door Jamb Switch?
steel2040
Door Jamb Switch? Empty
PostSubject: Door Jamb Switch?   Door Jamb Switch? EmptyWed Nov 28, 2007 8:53 am
Anyone know if we have a door jamb switch ? Cause when i turn my car off and open the drivers door the radio stays on. But when i open the Passengers it turns off. Same with interior lights so i assume its the switch the only thing is when you open the drivers door it does say Door Adjar.
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyWed Nov 28, 2007 5:01 pm
i was also wondering this cuz mine does the same thing
Stealofcentury
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyWed Jul 22, 2009 2:39 pm
I know this post is almost 2 years old, but did anyone have a solution to this problem?
Merit : 155
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyWed Jul 22, 2009 8:29 pm
the door latch has a switch inside it.
Your problem *might* be the switch but just as likely is a chafed or broken wire in the area where the wires pass out of the door and into the A-pillar - check that bundle of wires first. You might have to pull off the door panel. You probably need to get a FSM (factory service manual) for reference and remove/replace instructions.
Stealofcentury
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyWed Jul 22, 2009 11:35 pm
Thanks Albertj, its funny you mention that. I had to take the door apart to run wires for my trunk release and door locks for my remote start. As I was running the wires throught the boot at the door hinge, I saw 2 open wires hanging loose. Called it a night, but will fix them tomorrow and see if that is the problem. The other problem I have is the driver door lock switch is inop, heres hoping they both are fixed with these wires!
Merit : 155
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyThu Jul 23, 2009 3:38 am
i do not have the bulletin number but there was a bulletin from GM about problems with wiring on that pass thru and some sort of recommendation for inspection.
Stealofcentury
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyThu Jul 23, 2009 5:50 pm
Thanks again Albrtj. Those two open wires were for my door locks and my accessories cut off when opening the door. Repaired both wires and now everything works again. And here I was debating to buy a door latch.....
Merit : 155
PostSubject: Re: Door Jamb Switch?   Door Jamb Switch? EmptyThu Jul 23, 2009 6:31 pm
You are welcome. Drive safely.
Door Jamb Switch?
» Cabelas Door Buster Sale ~ Garmin 60CSX $199
» Help with a shower door
» 2 door wooden cupboard for sale - brand new!
» Radiator Thermo Switch
