 Error Code P1870
kennyj4
PostSubject: Error Code P1870   Thu Nov 29, 2007 3:29 pm
I've had an 1870 code for quite some time. The car feels like it has no power in 1st gear and the exhaust is heavier than normal. After driving I can smell a burnt smell.
Any thoughts? I've changed teh transmission fluid already and used seafoam to clean it also.
PostSubject: Re: Error Code P1870   Thu Nov 29, 2007 3:49 pm
P1870 Trouble Code; "Transmission Componet Slippage"
What year is the Riviera?
I think that trans is on its last legs
kennyj4
PostSubject: Re: Error Code P1870   Thu Nov 29, 2007 5:24 pm
Its a '96 with 123,000.
Other than having no power when I first accelerate it runs fine.
PostSubject: Re: Error Code P1870   Thu Nov 29, 2007 5:29 pm
check for a vac leak around the lines that go to the front of the tranny.
how does the fluid look? level?
kennyj4
PostSubject: Re: Error Code P1870   Fri Nov 30, 2007 12:00 pm
Fluid and level are fine
Merit : 64
PostSubject: Re: Error Code P1870   Fri Nov 30, 2007 1:19 pm
on the 1996 4L60e, to fix the 1870 code we stake the TCC regulated apply valve in the full-open position, which eliminates the PWM function. With the pwm function locked down, it then functions like a regular lockup. You don't need to reflash the PCM.
Don't know about the 4T60... I suppose it would be similar but you may want to check it out. THe 4L60e transgo shift kit addresses the issue. I don't know if the 4T60e transgo kit addresses it, butit includes the PWM valve, lock-up regulator valve & bushings.
Riviera96
PostSubject: Re: Error Code P1870   Sat Dec 01, 2007 9:46 am
With a 123000 miles you might as well spend your time shopping around for a rebuild transmisson.
Error Code P1870
