| LS1M scanner | |
T Riley Guru
| Subject: LS1M scanner Thu Jan 03, 2008 4:17 pm | |
| YAY new batteries........... only used once.......... hopefully NO KR......... | |
T Riley Guru
| Subject: Re: LS1M scanner Thu Jan 03, 2008 11:45 pm | |
| i bought some NEW batteries for my scanner......... because i used the scanner once and just forgot about it............. SOOOOOO i bought new batteries and did some WOT runs.................. first one....... 0.01 KR..... i was like huh.... sweet............. THEN i did a little 3-1 downshift FULL throttle going 40 and stomping it......... saw 4.3 KR AHHH ,,,, but i hope it was FALSE........... idk............. it maxed out at .09 after 3 more 0-95mph tests......... "i let off into third gear"................... i played with the 0-60 and i got a best of 6.65 which is DECE....... and the HP thing said 255 HP...... hahaha take that MAXIMA. | |
T Riley Guru
| Subject: Re: LS1M scanner Fri Jan 04, 2008 12:45 am | |
| GOTTA love 31* degree IAT temps.................YAY................. WHILE engine was at a solid 186 Degrees.......... i love this thing | |
oldsman105 Junkie
| Subject: Re: LS1M scanner Fri Jan 04, 2008 8:44 am | |
| I think your next mod should be a shift kit. | |
| Subject: Re: LS1M scanner Fri Jan 04, 2008 9:21 am | |
| You managed to find some snow/ice free roads? Be careful anyway, hate to see you hit some ice and lose it.
I'd like to hook mine up and do a couple runs and see how the 20deg temps affect my KR. If still having some, then swap my 3.8 mps pulley and check again. Haven't run the 3.8 with my current mods. | |
BillBoost37 Junkie
| Subject: Re: LS1M scanner Fri Jan 04, 2008 10:27 am | |
| I too believed that KR could be false at one time. A good friend that is an awesome tuner once told me that he has never found any "false" kr that couldn't be remedied with a proper tune.
I'm a believer that if you spend a lot of time learning and tuning, you can get a great tune that keeps you from seeing almost any KR.
This same friend took a B'ville to 13.1 seconds on the 1/4 with only 91 pump gas. | |
| Subject: Re: LS1M scanner Fri Jan 04, 2008 10:36 am | |
| Except for minor spikes at shift points, I have never seen false KR on my car. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BillBoost37 Junkie
| Subject: Re: LS1M scanner Fri Jan 04, 2008 1:06 pm | |
- Except for minor spikes at shift points, I have never seen false KR on my car.
Even that is not false. The method our cars use to reduce timing for shifts is KR. The pcm induces that KR at the shift on purpose. | |
T Riley Guru
| Subject: Re: LS1M scanner Fri Jan 04, 2008 1:48 pm | |
| [quote="1998 Riv"]You managed to find some snow/ice free roads? Be careful anyway, hate to see you hit some ice and lose it. quote] i live in MINNESNOWTA.............. and there is NO snow on the roads........ a little salt so NO TRACTION......... i could pull a 6.5 second 0-60 pass........... Me spin out ??? lolz | |
| Subject: Re: LS1M scanner Fri Jan 04, 2008 2:05 pm | |
| quote: "Even that is not false. The method our cars use to reduce timing for shifts is KR. The pcm induces that KR at the shift on purpose."
By my definition, if KR isn't produced from knock recorded by the knock sensors, it's false! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: LS1M scanner Fri Jan 04, 2008 2:09 pm | |
- quote: "Even that is not false. The method our cars use to reduce timing for shifts is KR. The pcm induces that KR at the shift on purpose."
By my definition, if KR isn't produced from knock recorded by the knock sensors, it's false! i really am not worried about KR when i am going 40 mph and go into 1st gear.................. what else should i excpect....... lolz | |
| Subject: Re: LS1M scanner | |
| LS1M scanner | |
