| Subject: Did my CV boot take a sh*t?? Sat Sep 10, 2011 12:07 pm | |
| Subject: Re: Did my CV boot take a sh*t?? Sat Sep 10, 2011 12:29 pm | |
| Yup, torn boot.
Two approaches. Replace the boot, or replace the CV shaft. To replace the boot requires the shaft to be removed, or else install a "split boot". I don't think split boots are very good. If you replace the boot don't forget to grease the joint first.
Generally, disassembling the CV joint is messy and a challenge, but not all that bad. Needs to be disassembled for a boot replacement.
If you aren't up for a challenge, just replace the shaft. | |
| Subject: Re: Did my CV boot take a sh*t?? Sat Sep 10, 2011 1:08 pm | |
| I just youtube'd the process. It doesn't look too bad. I would just replace the axle but all I hear from the w-body crew is that aftermarket axles are junk and OEM is $$$, plus I'm pretty certain mine has not spent much time getting crudded up with contaminents due to having a torn boot for a long time. I was just working near that area of the car a week ago and I would have seen something if my boot was torn and spitting out grease like you see it now. That shit is everywhere! So much for nice clean new cradle... | |
| Subject: Re: Did my CV boot take a sh*t?? Sun Sep 11, 2011 8:19 am | |
| Yeah there are def. issues with some reman axles - some will last forever, some will last a month. But they have a "lifetime warranty"!!!!11! | |
| Subject: Re: Did my CV boot take a sh*t?? Mon Sep 12, 2011 3:27 pm | |
| For the sake of saving time since I don't have much of it to spend right now I decided to pick up a new axle from OReilly's with a lifetime warranty. I think it was $70. I've read nothing but bad things on the remans so I'm hoping I'll have more luck with the new one. I'm definitely saving my old one and when I get around to it, I'll re-boot it and have it ready in case the new one craps out. | |
| Subject: Re: Did my CV boot take a sh*t?? Mon Sep 12, 2011 10:32 pm | |
| It's in. Pretty easy to remove/install. It took me more time to clean all the grease off the car than the actual replacement of the axle. My only dumbo move was that after I had the old axle out, I started the engine to turn the wheel a bit to line up the strut better which dumped about a qt of trans fluid onto the floor from where the axle goes in the trans. I'm at 202,605mi right now. We'll see how long this one lasts. | |
| Subject: Re: Did my CV boot take a sh*t?? | |
