| Those f"/$$%? gaz pump | |
Sag Enthusiast
Name : Martin Age : 42 Location : St- calixte Qc Joined : 2007-10-26 Post Count : 166 Merit : 0
| Subject: Those f"/$$%? gaz pump Tue Dec 04, 2007 4:08 pm | |
| Does anyone know if there is a rebuild kit or just a pump aviable cause the fuel pump assembly is a little costly and don't want paying a 6th time for unwanted stuff tanks for anykind of help (yes i'm shure it's the pump so no tanks for testing stuff) | |
| Subject: Re: Those f"/$$%? gaz pump Tue Dec 04, 2007 4:27 pm | |
| My 95-99 parts list only shows it available as an assy with the sender, sorry. You could try contacting Ed Morad if you want to try a used unit. Or check gmpartsdirect.com or rockauto.com | |
Sag Enthusiast
| Subject: Re: Those f"/$$%? gaz pump Tue Dec 04, 2007 4:30 pm | |
| There must be a rebuilding kit they take the cores(maybe i only tell that to convince miself)tanks | |
oldsman105 Junkie
| Subject: Re: Those f"/$$%? gaz pump Tue Dec 04, 2007 4:31 pm | |
| http://www.partsamerica.com/ProductDetail.aspx?MfrCode=PYN&MfrPartNumber=745208&PartType=52&PTSet=A
just the pump | |
Sag Enthusiast
| Subject: Re: Those f"/$$%? gaz pump Tue Dec 04, 2007 4:38 pm | |
| Grrrrrr i can't have a zip code i live in canada! but tanks a lot now i know it exist! | |
palermocorey90 Expert
| Subject: Re: Those f"/$$%? gaz pump Tue Dec 04, 2007 7:20 pm | |
| do a search for 1000 islands or alex bay thats near the canadia corder | |
| Subject: Re: Those f"/$$%? gaz pump Tue Dec 04, 2007 9:45 pm | |
| - Sag wrote:
- Grrrrrr i can't have a zip code i live in canada!
So petiton for statehood, eh? Then you can have a zip code! If you join though be sure to bring your health care system with you. It would make my life easier. | |
BillBoost37 Junkie
| Subject: Re: Those f"/$$%? gaz pump Wed Dec 05, 2007 6:23 am | |
| Also check TRE Performance on Ebay. I called them about my car (regular pump) and my truck (drop in assembly). The guy was very knowledgeable and I had 1 high flow pump for car and 1 regular pump at my house for about $130 shipped. Both perform awesome and I'm more than happy.
The assembly ones if it's the big can type setup I'm thinking of...then it's easy to undo the clips and remove the old pump to replace it. ZZP and INTENSE both have the instructions on their sites for installing Racetronix or Walbro pumps into GP's with that canister setup. | |
themba Rookie
| Subject: Re: Those f"/$$%? gaz pump Thu Dec 06, 2007 12:31 am | |
| A word of caution about TRE Performance, if you have problems they are extremely difficult to work with. Do no expect any returns, so make sure you read the fine print well. I brought a pump for my NA Riv and email and even called before I did to make sure it with fit. Well it did not and they refused to accept a return and gave me the run around. A complete fiasco. | |
BillBoost37 Junkie
| Subject: Re: Those f"/$$%? gaz pump Thu Dec 06, 2007 6:21 am | |
| Odd, my expereience was the opposite. They cross checked, sent once, all the right stuff and poof, once happy Boost. Good to know on the returns though. | |
Sag Enthusiast
| Subject: Re: Those f"/$$%? gaz pump Sun Jan 13, 2008 3:58 pm | |
| sorry for delay i found one for 300$ complete with sender so it's not that bad!! tanks all. | |
| Subject: Re: Those f"/$$%? gaz pump | |
