 need help pleaze
myjovon
need help pleaze Empty
PostSubject: need help pleaze   need help pleaze EmptySat Dec 15, 2007 9:33 pm
[b][u]i need help y 95 riv is making a knocking noise at 50 mph ans it seems to slow down like a loss of power does anyone know please help me . headshot
PostSubject: Re: need help pleaze   need help pleaze EmptySat Dec 15, 2007 9:59 pm
it makes it at 50mph cruising or while accelerating?
myjovon
PostSubject: Re: need help pleaze   need help pleaze EmptySat Dec 15, 2007 11:19 pm
accelerating
PostSubject: Re: need help pleaze   need help pleaze EmptySat Dec 15, 2007 11:21 pm
What grade fuel are you using? How long since fuel filter was changed?
myjovon
PostSubject: Re: need help pleaze   need help pleaze EmptySun Dec 16, 2007 5:26 pm
at about 55 it strts 2 stuter at 55 mph and i hear a ticking sound but when i drop it in neutran and rev it it dont do it?i changed the filter a month ago why?
PostSubject: Re: need help pleaze   need help pleaze EmptySun Dec 16, 2007 6:31 pm
Sounds kinda like a transmission issue. ... but are you using premium fuel?
BillBoost37
Merit : 25
PostSubject: Re: need help pleaze   need help pleaze EmptyMon Dec 17, 2007 6:52 am
Hi..
You'll want to answer the question about fuel. Premium is the only thing you want to run.
Then the plugs and wires are next on the list of usual suspects. If you don't know when they were changed, it's time to do both the wires and plugs at the same time.
Most ignition issues will show up once the car is in high gear.
I don't see anything that sounds trans related from your brief description. If a trans was causing this issue it would have very few miles left in it.
myjovon
PostSubject: Re: need help pleaze   need help pleaze EmptyMon Dec 17, 2007 7:59 pm
yeah it likes to studder and i start to hear a rattling when i put it in neutral i dont hear nothing in the motor and i floor it from 10 mph and it dont do it
need help pleaze
