 Painting Supercharger Rotors?
Painting Supercharger Rotors? Empty
PostSubject: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyThu Dec 20, 2007 4:09 pm
were my internals are im not sure what there called"the blades" on my supercharger, could i sand it down with 1000 grit to make it nice and smooth then hit it with 2000, it my winter project, i was just woundering
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyThu Dec 20, 2007 5:43 pm
Don't sand the lobes. They're coated with special stuff (epoxy or Teflon, depending) . Even if it's worn away, don't sand or paint the lobes. Best to either leave them be or replace them.
Merit : 135
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyThu Dec 20, 2007 6:07 pm
dont touch the blades or anything they come into contact with. If you pull it completely apart, efforts to smooth the roughness around the inlet area may be good. Some porting would be cool to since you got that northstar TB wink but be careful if you're gonna do anythign like that
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyThu Dec 20, 2007 6:13 pm
codith SHHHHHHHHHHHH i dotn want em to know about my TB
BillBoost37
Merit : 25
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyFri Dec 21, 2007 8:41 am
The name for them is the rotors. Removing coating would make them not seal as well. During an experiment in stupidity when I first learned about SC's I cleaned the rotors with TB cleaner that removed the coating.
It reduced boost about 2-3lbs. No other changes were made.
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyFri Dec 21, 2007 9:42 am
This is why you shouldn't use alcohol or water injection upstream of the TB. The tiny droplets act like micro hail stones when they hit the spinning lobes (I call them lobes). After a while, the all of the coating becomes stripped off.
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyFri Dec 21, 2007 10:28 am
i dont mean the rotors i mean the housing
Buickman104
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyFri Dec 21, 2007 3:29 pm
For the housing you can smooth out/port the intlet (part right after the throttlebody) and smooth out the outlet (part that the air come out from to go into the LIM). You should also smooth and polish the LIM. Remove all the roughness and leave it smooth and shiny. Also leave the compression chanmber alone (the part where the rotors are) that past is already smooth from factory and if you mess with the compression chamber all you will do is lose compression.
PostSubject: Re: Painting Supercharger Rotors?   Painting Supercharger Rotors? EmptyFri Dec 21, 2007 9:59 pm
thanks for the help man
» Painting lures
» MPI SUPERCHARGER for a 660 RHINO For Sale CHEAP!
» Painting Plastic
» SuperCharger for a 16HP/18HP Briggs and Stratton?
» Paint Gelding
