 Help...No Brake Lights or Traction Control!!
97Riv-Jon
97Riv-Jon
Help...No Brake Lights or Traction Control!! Empty
PostSubject: Help...No Brake Lights or Traction Control!!   Help...No Brake Lights or Traction Control!! EmptyFri Dec 21, 2007 6:58 am
This week I wason the road and when I tapped my brakes the dash brake warning light came on and then the "traction control off" light came on.
I pulled over and yep...no brake lights at all!
I checked the fuses on the driver side dash and all were fine.
Any ideas? Can't drive without brake lights... puzzled
Jon
Merit : 155
PostSubject: Re: Help...No Brake Lights or Traction Control!!   Help...No Brake Lights or Traction Control!! EmptyFri Dec 21, 2007 11:57 am
CHeck wiring from brake pedal to main harness for a connector wiggled loose.
Check the wiring from that CHMSL in your spoiler back to where it is spliced in to the origina wiring.
Also check wires at wheel sensors, may be a problem there that was a co-incidence with some wiring gremlin aout the brakes.
97Riv-Jon
97Riv-Jon
PostSubject: Re: Help...No Brake Lights or Traction Control!!   Help...No Brake Lights or Traction Control!! EmptyFri Dec 21, 2007 11:18 pm
Anyone know where the fuse or circuit breaker is for the brakelights/traction control?
» I'm back with a new FJ!
» Brake lights and turn signals
» POlaris rear lights blinking?
» Brake Switch
» control arm bushings
