 Cooler T-stat.. Whats the purpose?
RiviRuss
RiviRuss
Cooler T-stat.. Whats the purpose? Empty
PostSubject: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyWed Dec 26, 2007 6:08 pm
I never have really understood the purpose of a 180 dg. therm. Can someone help me out?
Thanks. Russ
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyWed Dec 26, 2007 6:23 pm
Your thermostat will open to cirulate water at 180 degrees instead of
the OEM 195 degree stat. SC engines like the cooler temps. from what I
understand.
RiviRuss
RiviRuss
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyWed Dec 26, 2007 6:24 pm
Thanks bud
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyThu Dec 27, 2007 9:40 am
Just switching to a 180 from the OEM 195 may not make much difference in your actual operating temps though. I did the 180 swap last spring, and saw no diff in op temps at all, UNTIL I also got my fan turn-on settings adjusted to come on at 185deg. Your coolant will start circulating sooner, but the fan settings make the big difference.
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyThu Dec 27, 2007 11:30 am
Agree. The 180 lowers temps when driving, but at idle you need the fans on to keep it consistent. A PowrTuner or HPTuners unit is required make the change, or performance PCM swap will do it. Problem is, you don't have these options for Series I, so it would need to be programmed custom by someone who knows.
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyThu Dec 27, 2007 4:36 pm
having a good clean cooling system with an additive like water wetter or purple ice will also help keep temps consistent.
name brand t-stat doesnt really matter much, i think i got Stant, and i havent had any problems here 5yrs in. they rarely fail unless your coolant is nasty.
Cooler T-stat.. Whats the purpose? Dsc_0110
RiviRuss
RiviRuss
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyFri Dec 28, 2007 12:25 am
So do you necissarily have to change your fan temp. too?
PostSubject: Re: Cooler T-stat.. Whats the purpose?   Cooler T-stat.. Whats the purpose? EmptyFri Dec 28, 2007 11:20 am
Not at all, it's just that would provide the most benefit, especially in stop & go traffic.
» Whats your deepest nugget
» Hydrostatic with Transaxle Cooler
» Koolatron P85 12V Cooler
» TEKNA as new 18" all purpose
» Whats your favorite tractor?
