| FAQ: Brake Rotors and Pads | |
+58RidzRiv al_roethlisberger matt270avian sniperdude 69GSColorado joshuadalegrimes MrWood88 charlieRobinson nothincame2mind gmann3001 J. Chris Davis pj_rage Abaddon robotennis61 Jayrydingslab flyineagle96 Hometown Hero Derek Fuzzy EatDirtFartDust GMfan1111 Snowdog blackbart95 Jack the R Eldo IBx1 Its a car part now lyonsperformance 1995 Riv Rickw manofmany captshiner Turbocharged400sbc 98SuperRiv Buapo palermocorey90 ewolfe0050 albertj deekster_caddy T Riley 99Rivman RhinoFLA allfalldown dreww Face SpaceBar HirohataMerc robertwolf86 turtleman 98riv racinfan TType_Riviera urbsnspices duffy NO 4 EVR Mr.Riviera jax95riv AA 62 posters |
| Subject: Re: FAQ: Brake Rotors and Pads Wed Oct 02, 2013 11:01 am | |
| I think the HPS should be fine for rear duty. As long as you have the EBC blue up front, you're going to stop pretty well. I also like the idea for EBC yellow or blue for rear. I might take that route in the future.
If Hawk considers HP+ to be a track pad, I think they're stretching things. Maybe for a Lotus Elise or FIAT 500, but for a heavy car like Riviera, HP+ is really more of a performance street pad. You can't road track a Riv with HP+ up front, that much I know for sure. For rear duty, they're more than adequate. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Brake Rotors and Pads Wed Oct 02, 2013 11:27 am | |
| agreed. I wish there was an EBC Blue that fit the rear but so far i have not found it. I have heard the yellow is the next closest thing to the HP+ in terms of friction level cold. I wasnt happy with the HPS when i had them up from (well i was happy at the time, but after trying other options i dont think i can go back).
BTW i did link this thread to my email i sent to hawk. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: FAQ: Brake Rotors and Pads Sat Nov 23, 2013 12:15 pm | |
| Well my rear rotors and pads are finally done. Finally? yea finally after only 6,700 street miles. The pads are down to the metal back plate and the rotors have a groove deep as a trench. (think two quarters stacked) Ill know when i pull them off but i am fairly confident they will be even and true across the board. Also no vibration from the rears even as thin as they now are. I ordered some EBC Yellow Stuff pads and powerstop rotors. Will be installing them over the holiday week.
| Subject: Re: FAQ: Brake Rotors and Pads Wed Mar 26, 2014 12:15 am | |
| Update: rear pads installed about 1 year ago are now about done. Long story short, my HP+ rear pads were wearing thin after a long life, so I ordered a new set, but received the wrong set in the mail. In desperation I ran to AZone and picked up a set of Duralast. They actually worked pretty well for awhile. It's only rears; they don't really do that much. However, in the last 4-6 weeks I've been feeling a faint shudder, not through the wheel, but from the rear. It's getting louder. I'm going to experiment and order a proper set of HP+ rears and see if things smooth out. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
RidzRiv Addict
| Subject: Re: FAQ: Brake Rotors and Pads Thu Aug 14, 2014 6:22 pm | |
| Hey guys, I am looking for something that will break to oem standards and will hopefully not warp. What do you guys think of these?
http://www.ebay.com/itm/FRONT-REAR-KIT-Black-Hart-DRILLED-SLOTTED-Brake-Rotors-Ceramic-Pads-C1300/121044652361?rt=nc
I am not currently interested in doing the F-body brake mod. I just want something that will stop the car and not warp, as I am getting sick of rotors warping on this car! | |
matt270avian Expert
| Subject: Re: FAQ: Brake Rotors and Pads Thu Aug 14, 2014 6:34 pm | |
| They're cheap and the black will wear off. I would get a set of Hawk HPS pads front and rear with some namebrand rotors. If they were drilled and slotted AFTER the rotors were cast they have a higher chance of cracking. If the slots and holes are cast with the rotor they will be less likely to crack. Most of the off-brand stuff does it the first way, and some of the name brand stuff does it the right way. Honestly, if you're not having warping issues and you're not beating on it you don't need drilled and slotted rotors | |
| Subject: Re: FAQ: Brake Rotors and Pads Fri Aug 15, 2014 9:13 am | |
| I've tried LOTS of rotor/pad combos (probably 10 at least). The best way to keep the car stopping strong without warping rotors is to spend your money on good pads, and really the only way to do that is to swap on F-Body calipers. That's the whole reason for the F-Body mod, really: so you can access the better pads.
But if you stay with OEM Riviera Calipers, about the best pad you can get are Hawk HP+. They are noisy, and make a tiny bit of dust, but your rotors will stay straight and clean. In fact, you will wear through a pair of rotors before you use up the pads - but they will not warp! Anything less, you just can't go braking the car as hard from higher speeds. So the options are: replace rotors every ~10k miles, buy HP+ pads and put up with the noise & rotor wear, swap to F-Body calipers, or don't brake so hard with this car. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
charlieRobinson Expert
| Subject: Re: FAQ: Brake Rotors and Pads Fri Aug 15, 2014 9:21 am | |
| I cant wait for some Fbody calipers and access to the pads! SO EXCITING | |
| Subject: Re: FAQ: Brake Rotors and Pads Fri Aug 15, 2014 11:44 am | |
| - RidzRiv wrote:
- Hey guys, I am looking for something that will break to oem standards and will hopefully not warp. What do you guys think of these?
I am not currently interested in doing the F-body brake mod. I just want something that will stop the car and not warp, as I am getting sick of rotors warping on this car! I've always been very pleased with Raybestos "Professional grade" pads and rotors. I found them on RockAuto for the '95 towards the bottom of the "daily driver" list under pads: http://www.rockauto.com/catalog/moreinfo.php?pk=298609&cc=1022016 and their front rotors here: http://www.rockauto.com/catalog/moreinfo.php?pk=299855&cc=1022016 I'm not a fan of drilled and/or slotted rotors, or cheap rotors. I've used these on my '98 Riv and it stops very hard, over and over, and lasts long. Used the same brand/model on many other cars as well and always been pleased. | |
matt270avian Expert
| Subject: Re: FAQ: Brake Rotors and Pads Fri Aug 15, 2014 12:30 pm | |
| FWIW I'm running Raybestos pads until I can get my F-bodys on and they feel kind of mushy. I don't really like the way they behave at low speeds either. You have to give it a decent bit of pedal to stop. Yes, my brakes are bled correctly.
I've been soaking my axle in PB every day now in hopes that when I get home tonight it will separate from the hub. Last time I tried they were rusted together. 95's and 96's require a knuckle/hub swap from the 97+ style for the F-body brakes. | |
| Subject: Re: FAQ: Brake Rotors and Pads Fri Aug 15, 2014 1:11 pm | |
| - matt270avian wrote:
- FWIW I'm running Raybestos pads until I can get my F-bodys on and they feel kind of mushy. I don't really like the way they behave at low speeds either. You have to give it a decent bit of pedal to stop.
Which ones? Raybestos has several varieties. My car with the above mentioned pads and rotors could toss everything in the car into the windshield on a tiny moments notice. Also, later Rivs had bigger rotors, earlier had smaller rotors. Grand Prixs had the same complaints on the earlier years with the smaller rotors. | |
matt270avian Expert
| Subject: Re: FAQ: Brake Rotors and Pads Fri Aug 15, 2014 6:13 pm | |
| Service grade. One of the pads I pulled off today fell apart. Not good. | |
RidzRiv Addict
| Subject: Re: FAQ: Brake Rotors and Pads Sun Aug 17, 2014 12:09 am | |
| Thanks for the info guys. I'll let you now what i get when I get around to it. | |
| Subject: Re: FAQ: Brake Rotors and Pads Thu Aug 21, 2014 9:55 pm | |
- I've tried LOTS of rotor/pad combos (probably 10 at least). The best way to keep the car stopping strong without warping rotors is to spend your money on good pads, and really the only way to do that is to swap on F-Body calipers. That's the whole reason for the F-Body mod, really: so you can access the better pads.
But if you stay with OEM Riviera Calipers, about the best pad you can get are Hawk HP+. They are noisy, and make a tiny bit of dust, but your rotors will stay straight and clean. In fact, you will wear through a pair of rotors before you use up the pads - but they will not warp! Anything less, you just can't go braking the car as hard from higher speeds. So the options are: replace rotors every ~10k miles, buy HP+ pads and put up with the noise & rotor wear, swap to F-Body calipers, or don't brake so hard with this car. What's worked for me are Raybestos ceramic pads (they are an OE for ACDelco) and ATE rotors with the grooved face. | |
| Subject: Re: FAQ: Brake Rotors and Pads Fri Sep 19, 2014 9:07 am | |
| Got these lil guys today. Anyone ever use em before? Based on the price, they better be awesome. Raybestos advanced technology (whatever that means) ceramic pads http://www.raybestosbrakes.com/magnoliaPublic/home/products/brake-pads/advanced-technology-disc-brake-pads.html These should hold me over until i get some Fbods ready to swap in.
Last edited by charlieRobinson on Fri Sep 19, 2014 9:31 am; edited 2 times in total | |
| Subject: Re: FAQ: Brake Rotors and Pads Fri Sep 19, 2014 9:28 am | |
| I usually use Raybestos, but I've never used slotted pads before. | |
Cappy Special
Name : Jay Location : Rock Springs, Wyoming Joined : 2014-09-18 Post Count : 9 Merit : 0
| Subject: 'performance' rotors stock?? Thu Oct 09, 2014 10:47 am | |
| Hey all... new to Buicks but not to vehicles. I bought a 98 Riv a couple of weeks ago. She's pretty mintish gold on tan. Anyhoo i noticed that there seems to be some hard spots on my rotors due to the way she's stopping...definitely not warpage. i thought id take a look yesterday....bam. To my surprise all four of my rotors are slotted and drilled!! | |
Cappy Special
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 10:48 am | |
| Whoops...so what i meant to ask was, is that stock? Or an option at least? | |
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 11:06 am | |
| Not stock OR an option. Somebody installed those.... Just out of curiosity, you can "feel" hard spots how | |
Cappy Special
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 11:38 am | |
| As a slight intermittent grind or halt while braking lightly | |
Cappy Special
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 11:39 am | |
| Or maybe then I should say 'rough' rather | |
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 11:46 am | |
| Ah. They probably have a thickness variation. Cheap rotors (I say cheap because I highly doubt someone spent $100/rotor for them) have a tendency to develop "high" and "low" spots within the rotor face after some time. I see it quite often. I wouldn't be surprised if you had rust rings exactly following the drilled sections too. This would most likely occur on the inner face of the rotor. | |
matt270avian Expert
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 12:20 pm | |
| +1 on the cheap rotors thing. Mine aren't too bad for what they are but I want to invest in some quality parts. | |
Karma Aficionado
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 1:17 pm | |
| I read this whole thread thinking we were talking about supercharger rotors. The concept was surprising to say the least. I'm an idiot. _________________ | |
| Subject: Re: FAQ: Brake Rotors and Pads Thu Oct 09, 2014 1:45 pm | |
| Subject: Re: FAQ: Brake Rotors and Pads | |
