 FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)
Go to page : 1, 2, 3 ... 10, 11, 12  Next
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) Empty
PostSubject: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyThu Dec 27, 2007 10:58 pm
So i took my engine cover off the other day to change the plugs and wires...and today i opened my hood ( cover still off ) and i noticed my boost bypass valve has completely dissassembled,..further more i looked and it seems like someone used some sort of glue to seal up the vacuum line leading to it... any ideas why this might have been done? and how much are the valves? any help is appreciated.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySat Jan 05, 2008 9:48 pm
Check it out man
Link
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySat Jan 05, 2008 9:50 pm
ok thats good to know because i definitely wanna replace that... thanks...
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySat Jan 05, 2008 9:52 pm
Cheaper than I thought it was
mr.19982tone
mr.19982tone
PostSubject: wut the? no supercharger boost   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySun Feb 03, 2008 6:22 pm
superchrger is not working feels like a doggy non-supercherged 3800 all the vacumelines are hooked up everything is where it belongs! anybody know wut might be going on?
https://s273.photobucket.com/albums/jj211/mr19982tone/
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySun Feb 03, 2008 9:04 pm
are the rotors turning? maybe your BBV is stuck open
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) Dsc_0110
Merit : 153
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySun Feb 03, 2008 10:13 pm
When did you first notice this?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySun Feb 03, 2008 10:43 pm
could be that the coupler has crapped out. Was there any noise under the hood that suddenly went away?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySun Feb 03, 2008 10:52 pm
How many miles on the car? Did this happen all of a sudden?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyMon Feb 04, 2008 8:44 am
make sure all your wires are hooked up to your plugs. i had a wire come off of one of the plugs one time. Can you still hear the supercharger whine?
mr.19982tone
mr.19982tone
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyMon Feb 04, 2008 9:49 am
yes the wine is still there everything is pluged in and one day it just had no power there is play in the supercharger wheel the motor and supercharger is supose to have 88,000 on them it worked good when i picked it up from the shop there is no skiping or anything its smooth just no power
Buickman104
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyMon Feb 04, 2008 10:57 am
Then it may be the Boost control solenoid. When they go they tend to just dump boost. They leave you with like 2 or 3 pounds of boost and just dump everything else.
mr.19982tone
mr.19982tone
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyMon Feb 04, 2008 6:46 pm
i will check that where is it located?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptySun Feb 10, 2008 9:20 pm
How'd you make out with this? Any new info?
BillBoost37
Merit : 25
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyMon Feb 11, 2008 7:07 am
The BCS/BCA are the black can and black electrical solenoid on the SC right next to the thermostat housing. (top radiator hose).
Deek.. with the alignment if you lost a coupler competely the pins would hit and still turn the charger. I doubt it would be good though.
mr.19982tone
mr.19982tone
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyThu Feb 14, 2008 5:31 pm
have not done anything with it its been shitty out so i have not been drivin it
arttu80
arttu80
PostSubject: NO BOOST in tha RIV!!!   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyThu May 15, 2008 3:07 pm
Today I hooked up boost gauge and so it was, no boost. Max 3psi at WOT!
I suspect control solenoid, but I would appreciate tips on troubleshooting.
In the picture below is control solenoid, and one port is open, WHY? May it be the culprit? Please help!
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) Img1104348
The car is 1997 Riviera.
Btw, I already replaced supercharger coupler and nose bearings, and I hear supercharger whine at WOT, so its not stuck or anything. I also checked that boost valve is moving, when I start the car.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyThu May 15, 2008 8:33 pm
that port should be open. and it is suposed to have a little filter on it but w/e.
still sounds like it could be the control valve or a vac line. does the arm on the BBV fully open/close?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyThu May 15, 2008 11:54 pm
mine did that the other day.
dont know what it was. Just chalked it up to the PCM cutting boost off because of a fueling problem. Normal boost now.
arttu80
arttu80
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyFri May 16, 2008 12:29 am
Well, I checked that BBV lever is going up when car is started and when it shut down, lever resting on intake plenum. So it is moving.
What's the good place to shop around for new boost control solenoid? I checked rockauto.com but they doesn't seem to have one...
BillBoost37
Merit : 25
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyFri May 16, 2008 7:24 am
Find one from other members for $10-15. GM wants about $30-40 IIRC.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyFri May 16, 2008 3:12 pm
mine is only getting about 7psi at WOT
is my BCS going out? Or do you really lose that much boost with a ported SC?
arttu80
arttu80
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyFri May 16, 2008 5:28 pm
Well, 7psi would be normal. According to 1997 Riviera/Aurora shop manual it should be around 7-9psi, so its ok. Mine is only about 2-3psi at WOT, so its not charging. My PA Ultra is Series I SC engine, and it feels much more quicker than 97 Riv with Series II SC motor, because of low boost.
I tried to eliminate bypass solenoid and even disconnected vacuum line from bypass valve, but its still 2-3psi. I'm hearing some "hissing" sound maybe from under blower, I guess it may be faulty plenum to supercharger gasket or something? I dunno yet.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyFri May 16, 2008 5:40 pm
is the vac line under the blower snout connected?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) EmptyFri May 16, 2008 6:35 pm
well 7-9 is normal for a 3.8 pulley on a stock motor. I got a 3.25" Sorry, didn't mean to hijack your thread. What was the theory behind bypassing the BCS?
yes. All my vac lines now run from that one port since I got the newer type SC housing.
Page 1 of 12Go to page : 1, 2, 3 ... 10, 11, 12  Next
» Kohler Courage 20 fuel shutoff solenoid bypass
» how much boost would it take....
» Fuel solenoid on a b&s intek 20 horse and it will not start.
» settings for gpx4000
» Hydrogen boosters on vehicles. Get better mileage.
