 FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)
Go to page : Previous  1, 2, 3 ... 5, 6, 7 ... 10, 11, 12  Next
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 Empty
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySat Oct 09, 2010 5:52 pm
J. Chris Davis wrote:
Ok, thanks. I'm gonna try that test when I get home tonight.
So, what's the verdict.? Do you need a new one or not.???
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySat Oct 09, 2010 6:45 pm
Eldo wrote:
No, he posted a non-Riv photo... (Bad boy! FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 Twak )
Notice the 'wrong' parts mounted to the passenger-side strut-tower?
OMG I can't believe I missed that. Fuse Box, engine mounts, the brace from the core to strut tower, the coolant reservoir.....I deserve that stick mad
PostSubject: Boost Control Solenoid availability - 10/2010   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySat Oct 09, 2010 7:20 pm
Aaron, I'll apologize in advance: I'm sure there's a better place to put this, especially after our latest PM's, but I just can't decide today... confused
Anyway, here is my latest experience for folks who need a new BBV BCS - can't have enough three-letter-acronyms can we? happy
While GMPartsDirect.com has currently suspended their online catalog because of parts that were
listed but obsolete, if you enter 1997244 into the part number field, you should find this valve...
I've enclosed 2 photos to show both the unit itself, and yet another term that GM used to describe it,
besides the ones that AA already listed in his parts thread. headbutt
Here is the GM parts tag, showing the number and the description as a "Supercharger Wastegate Valve":
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 5065527977_701c7dea03
And here is the actual part called an "Evap Solenoid", including the correct S2 bracket and a fresh breather-filter:
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 5066139976_74a51260ec
For once, the Delco number and the GM number are the same, except for the leading zero, and the total cost with shipping & handling was $38...
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySat Oct 09, 2010 7:27 pm
Actually, the 'stick' was for his posting of the non-Riv...
If I was going to criticize you, I would have used a lecture or a dunce
(I guess it's a moot point now... jump )
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySat Oct 09, 2010 10:18 pm
Ya sorry for the non Riv pic. It was what I had at the moment. I do need a new one. It's leaking a bunch of air out of the bottom of it. Found one on ZZPerformance for 40 bucks.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySun Oct 10, 2010 2:44 am
Does the one from ZZP fit other cars.?
Does it have the vacuum ports facing in the correct position.?
Etc, Etc............
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySun Oct 10, 2010 2:46 am
As far as I know it's the right one. I'll find out for sure when I get it.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySun Oct 10, 2010 8:49 pm
Perhaps the vacuum ports don't interfere with anything, because they're selling the same part for Series II and Series III... S3 has a Gen V, right?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyThu Oct 14, 2010 4:18 pm
Well I'm at work and got the valve in the mail here. It looks like the correct one. It is missing the little arm with the bolt threads on it for that one part to mount to. I'll find out more when I get home tonight to work on the car.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyThu Oct 14, 2010 6:43 pm
Ok the ZZP Bypass Valve is not the right one. The top vacuum port is in the wrong place and it is missing the part of the bracket for a vacuum solonoid.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyTue Nov 09, 2010 12:05 am
bummer. that # doesnt show anymore
PostSubject: No boost and EVAP codes...solved!   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyThu May 19, 2011 9:28 pm
I got a CEL this afternoon. Car was running strong this morning but later in the day it felt like it lost some TQ and HP.
Finally the CEL came on and i figured it would lead to something useful and explain the power loss.
P1655 and P1441 which from what i have been reading are both EVAP codes.
I pulled the charcoal canister from the rear driver fender and it feels pretty heavy. i turn it over and a orangeish oil substance drips out from where the vac line goes. Smells like fuel but feels like oil.
I am going to pull the line off the solenoid/purge valve and try to blow air through it to see if the line is clogged because im guessing this isnt normal.
Any other suggestions?
TIA
Matthew
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 Dsc_0110
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyThu May 19, 2011 10:51 pm
Looks like your covering all the bases. The only thing I can thing of is if its the purge solenoid valve itself. Thats what it was when I got that code. By the way, was it tuff getting those plastic fuel lines off the canister. I am afraid to remove mine as they look so brittle. How did you do it?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyThu May 19, 2011 11:02 pm
my lines were in pretty good condition. they dont push on very far and i left them in the top of the canister, just removed the bottom and the inside.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 8:38 am
Don't have much time, I'll elaborate later.......replace your Purge Solenoid.
Merit : 122
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 10:43 am
Abaddon to the rescue! Up Up and Away!
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 11:13 am
found out why it feels so sluggish now.
i am only making 4.3lbs of boost! WTF?
are these problems related?
i cleared the evap code and its hasnt come back on.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 11:15 am
according to another thread "QDM 2 is the BCS/Evap/TCC" so do i need a new pcm? or just a bcs and evap?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 12:32 pm
On your '96....
P1655 EVAP Purge Control Circuit
P1441 EVAP System Flow during non-purge
When P1655 is accompanied with P1441, 90% of the time the Purge valve is stuck open and allowing fuel vapors to just flow into the T/B and the S/C when not commanded to do so.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 12:49 pm
OK thanks Scott. I will swap out my BCS and purge vlave this weekend with some working solenoids from a friends regal.
So are my 2 issues non related? or did the failing purge solenoid cause the BCS to fail due to carbon and fuel entering the TB?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 4:13 pm
Np.....
I don't think the problems are related, just a mere coincidence. Your Purge Solenoid would have to be letting the vapors by for a long time for that to happen.....but then again, fuel is an excellent cleaner wink
Even If that were the case, the P1441 would've set long ago. Purge valves can get stuck, and still work electrically (GM 4.8L happens ALL the time), but will set P1441 (in the Rivs case) as soon as the PCM runs it's EVAP test. I would think all the carbon/soot buildup on the BCS is more oil/blowby related from the PCV system than anything else. Do you have another breather built into the oil cap? I drilled a hole in mine and glued a Crankcase Filter inside of it just so the PCV can keep up with all the boost..... twisted
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 4:26 pm
yes i am running a breather. and after the I/C install my PCV valve is doing nothing...still need to pull it out i guess.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptyFri May 20, 2011 4:28 pm
ah yes.....I can never remember what everyone has done to their ride dunce
lmao
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySun May 22, 2011 5:34 pm
So i swapped my BCS with one from another riv and i am still only hitting a max of 4.5lbs boost. WTF!?!
What else could cause a serious boost loss? i dont have a vac leak either.
EVAP codes have to be related somehow.
I am not having any TCC problems but i find it weird that the EVAP and BCS are both operated off the same quad driver.
Any way to replace that or test it?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 6 EmptySun May 22, 2011 7:55 pm
anyone?
Is the quad driver part of the PCM or something separate i can check?
All the fuses un the I/P and under the seat check out with an ohm meter.
Page 6 of 12Go to page : Previous  1, 2, 3 ... 5, 6, 7 ... 10, 11, 12  Next
» Kohler Courage 20 fuel shutoff solenoid bypass
» how much boost would it take....
» Fuel solenoid on a b&s intek 20 horse and it will not start.
» settings for gpx4000
» Hydrogen boosters on vehicles. Get better mileage.
