| identify this part! | |
+9AA 1998 Riv turtleman 99Rivman RhinoFLA IBx1 Mr.Riviera TonySmooth89 deekster_caddy 13 posters |
| Subject: identify this part! Sat Dec 29, 2007 10:03 pm | |
| then guess why it's there... | |
TonySmooth89 Aficionado
| Subject: Re: identify this part! Sat Dec 29, 2007 10:23 pm | |
| Looks like an engine cradle.... you blew mounts? | |
| Subject: Re: identify this part! Sat Dec 29, 2007 10:28 pm | |
| engine sub frame/cradle and you figured it easier to install the front sway bar this way?? j/k are you doing a swap? L32 maybe? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: identify this part! Sat Dec 29, 2007 10:34 pm | |
| getting close... clue #2: What's missing? | |
| Subject: Re: identify this part! Sat Dec 29, 2007 10:47 pm | |
| ZZP transmission? might as well slap on a billet flex plat while you have access _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: identify this part! Sat Dec 29, 2007 10:56 pm | |
| pretty close. It's a used thrasher trans I picked up cheap. 3.29s, shift kit, lsd, chain... had 20K miles on it and the price was right.
Started disassembly yesterday morning and I just drove it around the block. I can't believe I finished it in two days! | |
| Subject: Re: identify this part! Sat Dec 29, 2007 11:00 pm | |
| I was in the middle of the install when I realized the 3000 stall converter that came with it needed a different flexplate. I thought about it for a while and decided the stock converter was fine since I do mostly city driving anyway. | |
IBx1 Expert
| Subject: Re: identify this part! Sun Dec 30, 2007 7:45 am | |
| You might as well shine up those rotors, too! As long as they're exposed, you might as well get down and dirty on a clean car. | |
| Subject: Re: identify this part! Sun Dec 30, 2007 8:05 am | |
| - IBx1 wrote:
- You might as well shine up those rotors, too! As long as they're exposed, you might as well get down and dirty on a clean car.
well the rest of the car is not that clean And even when it is clean, it still looks like crap. the paint has oxidized all over the place. I'm going to start in an auto body class in '08 and we'll see what happens... I did put fresh paint on the 'new' transmission after some wire brush action though | |
RhinoFLA Aficionado
| Subject: Re: identify this part! Sun Dec 30, 2007 6:12 pm | |
| looks good bro, quite the upgrade | |
| Subject: Re: identify this part! Sun Dec 30, 2007 6:29 pm | |
| thanks, I just finished reprogramming all the shift points and am going to take it for another ride. notice the passenger side end link I am actually a little concerned about one thing: The back of the Riv case looks like this: The back of the GTP case: That mount is used more as a stabilizer than a load bearing surface, but I don't know how it will hold up over time with only 2 bolts instead of 4. | |
RhinoFLA Aficionado
| Subject: Re: identify this part! Sun Dec 30, 2007 6:38 pm | |
| so how much did you get it for | |
99Rivman Aficionado
| Subject: Re: identify this part! Sun Dec 30, 2007 6:42 pm | |
| Been there done that! What a pain in the ass! I didn't change it for anything special, just a used transmission, but a couple of days on your back is about right. How about that bolt that you have to use a 24” extension to get to from the passenger side! | |
| Subject: Re: identify this part! Sun Dec 30, 2007 7:36 pm | |
| - RhinoFLA wrote:
- so how much did you get it for
$1500 | |
| Subject: Re: identify this part! Sun Dec 30, 2007 7:38 pm | |
| that bolt... Interesting location. The first 3800 I pulled I didn't even know it was there. We were at our wits end trying to separate the engine and finally like WTF!! But since then I haven't had a problem | |
| Subject: Re: identify this part! Sun Dec 30, 2007 8:58 pm | |
| i got tripped up on the same thing while doing my old 3100 too | |
| Subject: Re: identify this part! Mon Dec 31, 2007 12:40 am | |
| - deekster_caddy wrote:
- ..... I'm going to start in an auto body class in '08 and we'll see what happens......
Damn, wish I had time for a class like that. | |
| Subject: Re: identify this part! Mon Dec 31, 2007 2:27 pm | |
| Hmmm. those pics I posted earlier about the rear mount, where the Riv has 4 bolts and all that webbing... the GTP case just busted open on my first test drive (no hard throttle!!) right around the middle/upper/main bolt. It's leaking fluid out of a crack right out the side of the case. I'll be pulling it out again this weekend, and having all the good parts swapped into my old case... | |
| Subject: Re: identify this part! Mon Dec 31, 2007 3:46 pm | |
| Ah, that stinks man... So it would be safe to say the GTP and Riviera transmissions are not interchangeable? I don't understand, did you use part of one with part of the other? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BillBoost37 Junkie
| Subject: Re: identify this part! Mon Dec 31, 2007 5:31 pm | |
| If I'm reading this properly the structural integrity of the case on the Riv was different than the GP.
Derek.. I've got an ATSG book if you are doing the work yourself. Just holler and we'll meet up to get that to you. | |
| Subject: Re: identify this part! Mon Dec 31, 2007 5:45 pm | |
| I just used a transmission from a '97 GTP. I have heard that the later cases were better, perhaps this is one of the reasons why. I don't know if all GTP cases are like that or just older ones, or maybe that was a GT case in the first place? I don't know the original history of the used one I bought, just since it's rebuild.
Whats ATSG? Automatic Transmission Service Guide? I'm probably going to use somebody local that I trust. | |
BillBoost37 Junkie
| Subject: Re: identify this part! Mon Dec 31, 2007 5:51 pm | |
| It's the rebuilding book. Automatic Trans Service Group. It's the GM Techtran manual.
I did a quick search on car-parts and found that the Riv,Bonne and Park Ave are considered interchangeable (SC app) and GP and Regals are interchangeable.
Makes me think that the case differences are based on those. | |
| Subject: Re: identify this part! Tue Jan 01, 2008 4:34 pm | |
| here's the carnage: | |
oldsman105 Junkie
| Subject: Re: identify this part! Tue Jan 01, 2008 5:26 pm | |
| Crap.... How much is going to cost to transfer everything into the Riviera case. | |
BillBoost37 Junkie
| Subject: Re: identify this part! Tue Jan 01, 2008 6:08 pm | |
| Derek..what year was that GP? | |
| Subject: Re: identify this part! | |
