| | FAQ: How to disable headlamps & daytime running lights? | |
| Author | Message |
BoattailBob Member
Age: 45 Location: Bay Area, California Joined: 2007-06-05 Post Count: 268 Merit: 0
 | Subject: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 1:26 pm | |
| This may be a lame question and posted in the wrong place so bear with me. I've never ran into this situation until the other night when I drove through this xmas lights display we have in one of the parks here. You are supposed to turn off your headlights and drive through. Well....I tried but could not figure out how to drive without my headlights on. So I had a bunch of irate parents yelling at me to turn off my headlights...it became quite amusing. Im so used to them coming on and off automatically that I have never had to do this. Anyone know how to drive the car without the headlights on? Mine are always in the off position but come on auto. There's got to be a way to do this. Surely someone has had to for a drive by at some time? |
99Rivman Fanatic
Name: Randall Location: North Carolina Joined: 2007-01-16 Post Count: 1623 Merit: 70
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 3:49 pm | |
| I just figured this out recently on my '99. The switch is spring loaded, you just push it all the way to min. and release it and it turns off the lights. As far as I can tell you cannot cancel the auto feature completely, it just turns them off that one time and the next time you restart or turn the key they will be on automatically again. |
IBx1 Aficionado
Name: ILAN Age: 20 Location: Westchester, NY Joined: 2007-12-30 Post Count: 4049 Merit: 65
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 3:52 pm | |
| My internet cut out on me, but I was gonna say that I know the light sensor tells the lights to come on even while the car is parked. My lights came on while it was on for us to install a neon stick under the dash, and I wasn't able to turn them off. Thanks, 99, for telling us how to do this! |
99Rivman Fanatic
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 3:59 pm | |
| I am pretty sure the '95 is different from the '97-'99, on my '95 I can completely turn off the auto feature, the switch is not spring loaded so you just push it all the way to dim and then you have to use the headlight switch to turn on the lights. If you are talking about the interior lights, there is no way to turn them off if the door is open but they will go off after approx. 15 minutes of the door being open. A battery saving feature.  |
SC95Riv Member
Name: Chris Location: New York Joined: 2007-10-20 Post Count: 134 Merit: 0
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 4:01 pm | |
| In my 95 I just set the switch to min and they stay off, I manually turn on my lights every night because the automatic lights wouldnt always turn on for me, so I'm used to doing it manually now. I figured it out pretty quick, I just assumed it was common sense to put the switch to MIN....  |
IBx1 Aficionado
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 4:02 pm | |
| Ok, so I just turn the knob all the way clockwise? Wow, I learned something new and helpful already!! I noticed that after 5 or so minutes, it also cuts power to the 12v DC outlet, very helpful! |
99Rivman Fanatic
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 4:10 pm | |
| | SC95Riv wrote: | In my 95 I just set the switch to min and they stay off, I manually turn on my lights every night because the automatic lights wouldnt always turn on for me, so I'm used to doing it manually now. I figured it out pretty quick, I just assumed it was common sense to put the switch to MIN....  |
That is true for the '95 but I think they changed it in '97 and it doesn't work the same way? |
turtleman Addict
Name: Codith Age: 24 Location: Villa Park, IL Joined: 2007-02-08 Post Count: 2655 Merit: 89
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 8:16 pm | |
| I have a 97. I don't know how to turn off the lights while in a gear other than park. This really makes me mad sometimes. I have that spring loaded sensitivity switch but it does nothing while in drive or even neutral. |
albertj Aficionado
Name: Location: Finger Lakes of New York State Joined: 2007-05-31 Post Count: 4901 Merit: 100
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sun Dec 30, 2007 8:38 pm | |
| I read somewhere that on the '96 and later RIv you push the parking brake pedal down one and only one click to make the headlights stay off while running. Sounded fishy to me & I have not tried it and do not plan to try it, but the directions stuck with me since I read it so I thought I'd share it in case you were curious. A lot of things have to be in adjustment for that little trick to work - the brake cable has to have enough slack, the switch has to engage, etc. I also read that on other GM cars (the Venture for instance) you can pull the DRL fuse and then the headlight switch will run the headlights. Why this would work to keep the headlights off at night I do not know. To read more on this see http://www.automotivehelper.com/topic111295.htm for the discussion. Albertj |
Name: Aaron Age: 34 Location: C-bus, Ohio Joined: 2007-01-13 Post Count: 14467 Merit: 172
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Mon Dec 31, 2007 11:59 am | |
| Albert, that parking brake method is quite amusing. I would absolutely NEVER do that! One time my front brakes got really bad (pads wore to the metal), so I had to use the parking brake regularly during the 30 mile drive home. I remember that if you are moving and engage the brake at all, you will hear a pretty loud and annoying "Ding-ding-ding-ding" until you release the pedal. Not worth putting yourself through this to make the lights go out, imo. Very annoying sound! _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
"I think that in any racing engine, the nearer you are to disintegrating, in general the better its performance will be." - Keith Duckworth, Cosworth Engineering
3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco F/Rsway bars • ES links/bushings • GM strut brace • Enkei 18" EV5s • Dunlop DZ101 tires F-body calipers • EBC bluestuff/Hawk HP plus • SS lines • slotted discs • ATE superblue fluid • DHP tuned • Aeroforce • Hidden Hitch
BoattailBob Member
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sat Jan 05, 2008 12:13 pm | |
They must have changed this in '97. I cannot get this to work, and believe me I tried it the night I had all these grumpy old men yelling at me "TURN YOUR LIGHTS OFF". lol |
deekster_caddy Guru
Name: Derek Age: 40 Location: Reading, MA Joined: 2007-01-31 Post Count: 6091 Merit: 83
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sat Jan 05, 2008 6:01 pm | |
| yeah I have never been able to turn off the auto lights in my '98 and I tried lots of things (but not the E-brake thing) |
TonySmooth89 Addict
Name: Anthony Age: 23 Location: Florida Joined: 2007-11-14 Post Count: 2411 Merit: 16
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sat Jan 05, 2008 7:09 pm | |
| Well on my car if you set it all the way to max you can kinda feel it click and the lights go off. |
albertj Aficionado
 | Subject: Re: FAQ: How to disable headlamps & daytime running lights? Sat Jan 05, 2008 10:04 pm | |
| Time to check out that DRL fuse.
Albertj |
shrek Newbie
Name: Shrek Location: Romulus,MI Joined: 2010-04-16 Post Count: 6 Merit: 0
 | Subject: help!!!!!! how to disable DRL Fri Apr 16, 2010 9:16 pm | |
| new owner of a 97 riviera and LOVE IT.............. But how do i disable the daytime runnings lights.... HATE THEM could not find anything in owners manual about it...
Thanks Shrek Detroit,MI |
