 FAQ: Good Scanner/Tuner Software to use?
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Thu Mar 13, 2008 6:07 pm
98riviera98 wrote:
RhinoFLA wrote:
I found a KR gauge for 75 bones, i'll keep looking.
really??????/ where??? do you think autozone, pepboys, or checker would sell them????
No, I don't think they would sell them, but I haven't checked. Here's the $79.00 single gauge I found.
http://race-tech-designs.com/store/catalog/Knock-Retard-Shipping-12-19-p-16138.html
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 10:46 am
Shintsu wrote:
lol, we never checked knock on it but for the record it was not and never was my car. His first mod was the 3.4" pulley (Yeah, that was smart...rolleyes).
Travis, which of those scanners is the cheapest (I can't use a tape measure for a damn in small/tight areas)? That's the thing, I don't mind buying a scanner but does it do nothing but measure KR or is it multiple things? Does the fact I have a '96 make a difference in this case as well?
research, research, RESEARCH!!!!!!!!!!
LS1M, Autotap, DHP, HP tuners,
cheapest cheap not cheap NOT CHEAP
Does everything AND KR
like 120 different things.......... www.ls1m.com
PostSubject: Need to know Which scanner   Wed Sep 24, 2008 3:43 pm
Ok So I got all the shit to put my 3.4 pulley on and I want to know what scanner or tuner I need ?
http://www.Chitownracing.com
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 3:59 pm
why do you people move my posts
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:00 pm
this post is for whats good thats nice i want to know what i need not whats good,
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:10 pm
I moved it because we don't need another "What scanner should I use" topic. Everything you need to know is on page 1 of this thread. If not, ask questions here, and we'll add to the topic.
Come on now... Are you serious?
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:11 pm
and i dont have a laptop so how does this post help me
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:15 pm
Sixth post down:
Any OBDII scan tool should work with your '96. I really like the AutoTap software, but LS1M looks good, too. These run on a laptop or Palm device.
If I were wanting to tune, I'd spend the extra on the new HP Tuners software, or find a good deal on a used DHP Powrtuner. You will need a laptop to run either. Both do the same thing, but HP Tuners appears to have better support and easier-to-use interface. As for working with a '96, I think DHP has done it already, and HP Tuners could if you asked them.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:18 pm
man To much shit is there anyone close by who a=can tune it for me? And what does the scanner do, is it something that stays on the car or idk inform me
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:25 pm
A scanner tells you what your engine & car is doing. It can record while you drive, or can be used real-time, mounted as a guage (Aeroforce). More:
http://rivperformance.editboard.com/series-ii-scans-tuning-pcm-f5/do-i-need-a-scanner-t31.htm
More on Aeroforce:
http://rivperformance.editboard.com/series-ii-scans-tuning-pcm-f5/aeroforce-scan-gauge-t3986.htm
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:26 pm
LS1M can only be had used now, but works pretty well. Autotap is a good scan tool. Those 2 are ONLY scanners, they do not tune anything. They can monitor much much more than just KR.
DHP and HPT are tuners, that include scan tools. They are much more $$$, and require some work on the owners part in order to put to use for tuning. I've had a DHP Powrtuner for a year, and have yet to use it.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:29 pm
So for A scanner I can get the aeroforce but for my car to run right i need a tune after i put the oulley on ?
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:37 pm
ok let me see if Igot this right, I know Im slow, So the scanner is to tell me whats happening and te tuner is to change it
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:38 pm
Only a tuner can make changes to your programming, plus you need to have a clue what you are changing, and how to do it.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 4:39 pm
thats why I dont want to buy a tuner, Cant someone who has one do it to someone elses car?
Bingo. That's basically it. Keep in mind that a Tuner package will also include Scanning software.
Yes, if you can find someone that will do it for you, it can be done by anyone with a tuner for your specific car (not common for the Riviera). But that person may not want to do tweaks every weekend, or it may add up if they charge for the service.
From personal experience, tuning isn't usually right the first time unless you have a wide-band and a dyno ($$$$). Having your own equipment makes it easier and less expensive to make adjustments whenever you need to.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 7:54 pm
Oh My goodness
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Sep 24, 2008 8:17 pm
Yeah i figured i wouldnt get it right the first time but shit i aint got that kinda money to buy a tuner right now
96RIVMANN
PostSubject: Code readers   Tue Nov 03, 2009 7:37 pm
I am looking into buying a code reader like autoxray or etc and was looking for some input. I'd like to keep it under $200.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Tue Nov 03, 2009 8:33 pm
I have an Actron CP 9145 that I bought a few years ago and it reads OBD1 and most OBD2 parameters and codes. Has been very useful over the years.
This model probably isn't made anymore but I see better ones on the market for less than your $200.00 budget.
Advanced Auto Parts and Auto Zone carry these and have sales frequently.
You can look on Amazon also, I've seen code readers and scanners on there for cheap money.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Tue Nov 03, 2009 8:46 pm
If you can, look for a used autotap. Much better than just a code reader, also a great scanning tool. I see them used for under $200 frequently.
96RIVMANN
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Tue Nov 03, 2009 8:59 pm
Auto tap is vehicle specific right. I am wanting to use it on different vehicles such as my parents Cadillac and sisters Suburban.
Merit : 131
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Tue Nov 03, 2009 9:06 pm
Consider Alex Peper's "CarCode" that you'd use with your PC and a cord available from Alex. www.obd-2.com will get you there. I use this one.
Albert
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Tue Nov 03, 2009 10:32 pm
I'm also going to be shopping for a code reader only tool. I just want to be able to read the code and clear it as needed. That's why I sold the LS1M, I'm finished with scanning and mods, etc, just want a simple tool. There's plenty to choose from, but I haven't looked too closely at any yet.
PostSubject: Re: FAQ: Good Scanner/Tuner Software to use?   Wed Nov 04, 2009 6:26 am
no, it will scan anything. There is a GM specific expansion package as an add-on, but most of the ones you find say if they have it or not. Check out their website.
Page 2 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
