 Dome lights stay on
mds66801
Dome lights stay on Empty
PostSubject: Dome lights stay on   Dome lights stay on EmptySat Jan 05, 2008 12:00 am
Recently I had an issue with my 90 riviera dome lights staying on. Also at the same time the radio that used to stay on until a door is open shuts off with the key. I first thought that it may be a door sensor but it doesn't show door ajared. I checked the relay under the back seat for the dome lights and it is engaged/charged at all times. What controls the dome light/radio cutoff? Could it be a door switch? I unplugged to ones on the drivers door and it made no difference. The interior lamp switch is off as is all the map light switches. Where would be a good place to start? hammer
Merit : 153
PostSubject: Re: Dome lights stay on   Dome lights stay on EmptySat Jan 05, 2008 12:20 am
chekc for a place in the bundle of wires that goes thru the door jamb into the door, where he wires flx, for scraped-thru insulation.
mds66801
PostSubject: Re: Dome lights stay on   Dome lights stay on EmptySat Jan 05, 2008 8:38 pm
No bare wires everything looks good.
PostSubject: Re: Dome lights stay on   Dome lights stay on EmptySat Jan 05, 2008 8:46 pm
I would suspect the door switch. You did check the dash lamp brightness adjuster, right? It's not all the way over to the dome light position?
mds66801
PostSubject: Re: Dome lights stay on   Dome lights stay on EmptySat Jan 05, 2008 10:12 pm
It's not the lamp brightness adjuster as that was the first thing I checked. As for the door switch it has the ones built into the door latch setup. I unplugged the harness in the drivers door and the light was still on, I will try the passenger side tomorrow morning. Also if the door switch wire was shorted wouldn't it say the door is ajar?
Dome lights stay on
» LED Dome Lights
» Ice Dome Oberstdorf
» HID lights
» Factory Steering rack & Tail lights
» ddm tuning hid lights any good ?
