 Just making sure... (Electrical)
Just making sure... (Electrical) Empty
PostSubject: Just making sure... (Electrical)   Just making sure... (Electrical) EmptyMon Jan 07, 2008 11:57 am
Do our 8th gen Rivieras have any serious electrical issues? I have a '95 with power everything and a heated seat, and if the wiring goes I want to know about how much it'd cost, if anyone has had to do that. I don't know if the new speakers I want to put in will mess with the electrical system at all, but if it does I want to know how much I'll be out. Thanks!
PostSubject: Re: Just making sure... (Electrical)   Just making sure... (Electrical) EmptyMon Jan 07, 2008 12:14 pm
Unless you do something radical to the stereo, and it's something that draws lots of power, it's not going to interfere with the car's electrical system. Even then, our cars make a lot of current, and should be able to keep up with most high-output stereo systems. I've added a true 300 Watt system in mine with no issues.
Not sure about the '95 year, but my '98 has had very few electrical issues. Most of my controls still work very well. I've never had to remove any wiring or electrical components other than the alternator and head lamps.
PostSubject: Re: Just making sure... (Electrical)   Just making sure... (Electrical) EmptyMon Jan 07, 2008 1:08 pm
That's good to hear, because there's an alternator with less than 500 miles on it under my hood. You already know what I plan on doing with the audio system, so I should be safe. If I put in an amp, will that draw a lot of power from the car?
PostSubject: Re: Just making sure... (Electrical)   Just making sure... (Electrical) EmptyMon Jan 07, 2008 1:17 pm
The kind of amp you're thinking of will be no problem. Don't worry about it. You want to start being concerned when you are throwing 400 Watts or more into subs. At that level, using a class D style amp will help you out.
PostSubject: Re: Just making sure... (Electrical)   Just making sure... (Electrical) EmptyMon Jan 07, 2008 1:56 pm
Well, I don't plan on putting in subs, so I'm safe! Thanks!
» Making a GO-Kart
» Lure Making
» making a living
» Making bait Newport ,MDR, Alamitos , Cabrillo
» First attempt at lure making!
