 mass air flow?
mass air flow? Empty
PostSubject: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 2:35 pm
ive been reading the posted threads about maf cleaning,and went to the store and bought some gunk maf cleaner,opened the hood and looked for the typical maf sensor sandwiched between the intake pipe and the filter,and dammed if i could not find it! uhhh mind if i ask where it is scratch
PostSubject: Re: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 2:37 pm
its on the throttle body.. you will need a torx screw driver to remove it......... it is a rectangle black box with 4 wires going to it............ take the screws out and pull out carefuly...........
PostSubject: Re: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 2:41 pm
mass air flow? L67TB
its on the left side middle thumbsup
PostSubject: Re: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 5:33 pm
um, i dont know what "left side middle" you're refering to but AFAIK the MAF sensor is not pictures there. it goes in the hole right above the TB opening.
looks like this on 95/96 rivs and a little different on 98+
mass air flow? MF5519_FULL
be very careful cleaning it b/c a new one can set you back ~$200
mass air flow? Dsc_0110
PostSubject: Re: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 9:31 pm
mass air flow? Maf10
i see the mass air flow suspect
PostSubject: Re: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 9:39 pm
i thought that was the IAC valve?
PostSubject: Re: mass air flow?   mass air flow? EmptyMon Jan 07, 2008 10:14 pm
well first of all...... i dont think this is the throttle body off of a L67 sorry about that.. i just typed in L67 throttle body and thats what came up........ but yess that is where the general location of the MAF is BUT it is on top and has 4 wires going to it ALMOST positibe its yellow, green, blue, red....... or along those lines
GOOD luck robotennis61....... Git R Clean
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 12:19 am
thanks people! who wud a thunk it?
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 4:14 pm
mass air flow? Maf11
THERE IT IS grimace
thanks Jason
96RIVMANN
96RIVMANN
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 4:59 pm
mass air flow? Imgp3149ra9
Here's my throttle body after a good cleaning. I went as far as to remove the butteryfly and polish it with some Mothers aluminum polish. Came out real nice.
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 7:55 pm
actually, what you circled is the TPS (throttle position sensor). The MAF is the empty hole in the middle near the lower part of that picture. That's a picture of the TB with the MAF removed!!
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 8:05 pm
OOOPS.............. mistake takin.......... i should have noticed the screw holes........... SORRY MR. RIVIERA!!!!!!!!!!
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 8:37 pm
its cool cool
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 9:09 pm
it's all good, just wanted to make sure you knew what you were looking at smile
PostSubject: Re: mass air flow?   mass air flow? EmptyTue Jan 08, 2008 10:36 pm
i got it! it came out pretty easy, and looked clean enough...but after cleaning it ,and reinstaling, i did notice a better throttle response,just tapping the peddle in park......only thing left to do is instal a cai........and cat delete.......
96RIVMANN
96RIVMANN
PostSubject: Re: mass air flow?   mass air flow? EmptyWed Jan 09, 2008 8:31 pm
Take the whole throttle body off and clean it. You won't believe how much better your car will run.
PostSubject: Re: mass air flow?   mass air flow? EmptyWed Jan 09, 2008 9:42 pm
u bet....thats on the menu too......!!!
PostSubject: Re: mass air flow?   mass air flow? EmptyWed Jan 09, 2008 9:50 pm
150k and I've never cleaned my TB. Somehow, mine still manages to idle pretty well.
96RIVMANN
96RIVMANN
PostSubject: Re: mass air flow?   mass air flow? EmptyThu Jan 10, 2008 7:41 am
Aaron, when you get the time take yours off and have a look. It seriously only takes about an hour to do the job. Just buy a new gasket before hand and your set. You won't believe all the black crud and carbon that is built up in the throttle body and up into the super charger.
PostSubject: Re: mass air flow?   mass air flow? EmptyThu Jan 10, 2008 9:33 am
you would be surprised how much a little layer of carbon can effect. the difference in throttle response is amazing. it was one of the first things i did to my car when i bought it back in 2005. now,rather than taking it off, i just remove the MAF screen, open the butterfly vavle and look in there with a flashlihgt wink
PostSubject: Re: mass air flow?   mass air flow? EmptyThu Jan 10, 2008 9:44 am
Yeah, I need to do this. How much coolant do you lose when taking it off? Should I lift up the car on the driver side?
PostSubject: Re: mass air flow?   mass air flow? EmptyThu Jan 10, 2008 10:35 am
if the car is completly cooled off then you may loose a pint. i think i took of the cap to loose some pressure before taking off the TB. nothing a little water cant top off.
96RIVMANN
96RIVMANN
PostSubject: Re: mass air flow?   mass air flow? EmptyThu Jan 10, 2008 1:06 pm
Maybe a 1/2 once at the most. No need to lift up the car.
werdstrave
werdstrave
PostSubject: Re: mass air flow?   mass air flow? EmptySat Jun 02, 2012 3:13 pm
Hey guys,
I'm experiencing some engine choke after I start the car when it's at idle or in park. It sounds like the car is getting ready to stall out. After I rev the engine at a stop or once accelerating from a stop is when it does this. After putting my foot way down on the gas pedal it will suddenly rev way up and take off. Seems like I need to flex the peddle a couple of times to get it to wake up. After getting it moving there is no stalling or sputtering at all.
Do you guys think this is the MAF sensor? Before I had this problem, I replaced the idle air control valve so I know it's not that. Any recommendations on how to clean the MAF?
PostSubject: Re: mass air flow?   mass air flow? EmptySun Jun 03, 2012 12:46 pm
what you describe sounds like when I was running with no maf sensor (during some tuning work). Is the SES light on? Any codes?
mass air flow?
» mass air sensor
» NIke Lunar Flow
» 54400111 a-460 trick flow intake new or used
» NHL Suspension Flow Chart
» Chemical weapons..mass murder
