 Cassette Release
Rivgirl06
Rivgirl06
Cassette Release Empty
PostSubject: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 1:06 pm
My cassette player says that there is a type in it, but there isn't. Does anyone know where the release is so i can actually put a cassette in it for my ipod? If that made any sense.
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 1:11 pm
There should be an eject button around the cassette deck. I have a '95 with the tape deck, ashtray, then CD player layout from top to bottom, so I don't know what your radio looks like. If noone answers, check in your owner's manual.
Rivgirl06
Rivgirl06
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 1:18 pm
when you push the eject button it just makes a really bad noise. i need to know their is a release inside that i can push to make it release. I don't have a cassette in it and i have never put on in it. so it says an error every time you push the eject button. does anyone know where the release is inside of the player?
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 2:03 pm
Doesn't sound good. I don't know if there's a mechanical release, but if you send a private message to AA or one of the other admins here, you'll probably get a solid, quick answer.
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 2:15 pm
hmmm if there was a tape in it id sat use a screwdriver to lift it up but idk... sounds like youre deck might just be busted... my old car did that and it really wasn't fixable.
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 2:18 pm
My tape drive has never worked. The factory tape decks suck big time. Once I had my dash apart so I took my radio out and wedgied the cassette loading tray back into place but it still won't load anything and makes the buggity noise.
Get an FM transmitter smile
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 2:56 pm
Maybe this will help (sorry, probably not the answer you were looking for):
http://rivperformance.editboard.com/audio-electronics-f7/how-do-i-extract-a-cassette-from-a-98-riviera-t158.htm
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 5:01 pm
Haha, after looking there, it seems like our cars have an appetite for tapes! One guy even bought his with one stuck in it to boot.
My tape-to-3.5mm adapter works fine in it, ejects out and slips in, but while it's running it makes a clicky noise if the volume is low enough.
PostSubject: Re: Cassette Release   Cassette Release EmptyTue Jan 08, 2008 5:41 pm
I just play CD's and listen to FM radio. smile
Cassette Release
» home made quick release steering wheel???
» Stawell Gift MEDIA RELEASE
» Fixture release date...
» New Release GARMIN Oregon 600's
» Considering a rec release
