 CAR PROBLEMS
Go to page : 1, 2, 3  Next
CAR PROBLEMS Empty
PostSubject: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 5:58 pm
i had a buddy that works at the local Cadillac dealer come on over so we can take a look at the riviera, and he had me try to start it with the fuel pressure gauge and it read 29-30 PSI what could be wrong with it and what parts do i need
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 6:08 pm
Try reading it under load at WOT.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 7:04 pm
you should read it with the engine running and vacuum gauge disconnected from the fuel pressure regulator. At 30 psi it should have enough fuel to start, I wouldn't count it as low fuel pressure unless you are at operating voltage (engine running).
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 7:10 pm
the 30 PSI was at WOT
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 7:15 pm
come to think of it, I keep forgetting yours is a '95 (you should keep that in your sig somewhere). I don't know what FP should be on a series I.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 7:50 pm
FP is 43-48 supose to be,
i will fix the sig
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 8:49 pm
fuel filter been replaced?
CAR PROBLEMS Dsc_0110
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 9:03 pm
yupp
CAR PROBLEMS Empty
should i just replace the whole fuel system
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 9:07 pm
I had the same problem, not enough fuel pressure. After I changed the fuel filter and still had the same problem, I added a hp pump and it took care of it. I will check with my source to see if you can use the same pump. It is made for a GTP and requires a little modification.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 9:08 pm
You will want a little more umph if you plan on modding... I also went with a hd wiring harness which was easier to install than the pump.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 9:10 pm
were can i get one
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 9:20 pm
Racetronix is the manufacturer. I believe my source got it from Intense but I will check. Let me see if it will work for series I before you get anything. I'll do it in the morning.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyWed Jan 09, 2008 9:21 pm
BTY... are those wheels photoshopped on your sig or is that what your cars wearing? I like regardless...
BillBoost37
Merit : 25
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyThu Jan 10, 2008 9:12 am
According to the FSM pressure should be tested w/o the motor running. Like others mention though..I've seen reasonable pressure not running and poor pressure running, especially at wot.
I replaced with a TRE pump and have been thrilled with the performance. Look for higher flow as well as higher pressure.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyThu Jan 10, 2008 3:10 pm
i also tested it not running that was at 28
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyThu Jan 10, 2008 3:20 pm
You need to find out if the fp canaster is the same on yours as it is on the later models. The SII might have a higher flow fp than the SI but the canaster should be the same. You can probably get part numbers from the dealership. If it is the Racetronix pump will work.
Merit : 154
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyThu Jan 10, 2008 7:22 pm
You might want to replace the in-tank fuel pump. If you have a little time on your hands get the rebuild kit from an ACDelco pars dealer - the replacements are pricey (I've seen $400) but the metal jacket pump itself is less than 1/4 that, around $40 or $60 IIRC.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptyFri Jan 18, 2008 10:24 pm
Merit : 154
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptySat Jan 19, 2008 1:14 am
the '98-00 L67 I think BUT DON'T take my word for it, see what ewolfe (or who was that sent you to zzperformance) says.
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptySat Jan 19, 2008 7:44 pm
BUMP any one know what year i should order or if it i need to know ASAP
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptySun Jan 20, 2008 12:11 am
Call Paul @ prg performance. He'll hook you up. There is some slight modification to be done which he can walk you through. He can probably save you some cash too...
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptySun Jan 20, 2008 12:22 am
Eric, what is Paul's contact info?
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptySun Jan 20, 2008 12:31 am
yea i just need to get back and forth to work i dont like buying gas for the titan
CAR PROBLEMS Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS EmptySun Jan 20, 2008 10:31 am
His site was down last night.. probably cause he found out I told another Riv owner about him. He is die hard GTP but somehow I get him to work on my car. He swears each time he sees my car he will not touch another Riv again. He's learning tho... 317-537-4004
CAR PROBLEMS Empty
CAR PROBLEMS
» RZR Wheel Hub Problems?
» 3500 still has problems
» GPX 4000 Problems
» Transmission problems
» Weber alternator problems
