 CAR PROBLEMS
BillBoost37
Merit : 25
CAR PROBLEMS - Page 2 Empty
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Jan 20, 2008 4:27 pm
I don't have the canister in the car, but do in my truck. TRE Performance on Ebay hooked me up when I sent a message and called them.
Might be another possible way to go. I've been very happy with the pumps so far. One person I heard ..did have some trouble with TRE, I would suggest calling and double checking with them before ordering.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Feb 10, 2008 12:12 pm
BUMP does any one know if the S2 fuel pump will work with a S1
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyThu Feb 14, 2008 6:45 pm
ok well be fore i go to buick and buy a pump lets go over a few things
what could be the reason why my car has a low pressure, im getting 28-30 around that, and it will crank and run but only last a few seconds. im not sure if ita a sensor or not. any help would be great guys
i know most of you have series 2 but please help me out
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyThu Feb 14, 2008 9:04 pm
If it consistantly starts, then dies, I don't think it's FP. It sounds more like a VATS problem to me. Does your security light stay on?
even if 28 PSI is low, the car should run and idle. Maybe performance would be off a bit, but I really thing you're barking up the wrong tree with the fuel pump.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyThu Feb 14, 2008 9:05 pm
28-30 PSI should be enough to run at idle. Have you tested cylinder compression?
If your engine isn't running, how are you measuring fuel pressure at WOT?
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyThu Feb 14, 2008 9:29 pm
i didnt thats just the turning the key to acc,which turns on the pump correct. to crank over the engine
PostSubject: FUEL AIR SPARK   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 3:24 pm
ok my car is getting air and fuel but im not sure about spark. ok after talking to the guy im keeping the car he tried to talk me down to 650.
so should i get some coils and try that out then get the fuel pump. if im correct with an engine fuel air and spark = running clap
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 5:15 pm
will, yes all you need is air, fuel and ignition source to have a "engine". but you also have to have 100 other things working in sync for it to run right.
test the coils and pump before dumping money into things that may not fix it.
CAR PROBLEMS - Page 2 Dsc_0110
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 6:18 pm
were can i get them tested
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 7:52 pm
most auto parts stores will test coils and other things like that.
Merit : 153
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 8:26 pm
I still think your crank sensor is broken.
If I am not mistaken it is one of the few things, if not the one thing, that will keep a Riv from running that won't set a code of some sort.
Easy to replace if you can get the harmonic balancer off. When I had mine replaced I paid a little over $100 to have the dealer do it - they have a special tool that makes it pretty simple. Takes them less than 45 minutes to do it.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 8:59 pm
could i do it in my driveway
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 9:13 pm
i did, but i had tools on hand. got the sensor for like $15 and installed it all by myself. no problems since.
you have to use a breaker bar and bump the starter to loosen the crank bolt, but other than that it is pretty simple.
there is a write up on clubgp IIRC.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptySun Apr 06, 2008 10:00 pm
Reach in there and make sure it's plugged in! It's hard to see... get real close.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyMon Apr 07, 2008 4:02 pm
ok im having my coils tested tomorrow , and i ordered my OBD-1 scan tool
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyMon Apr 07, 2008 6:05 pm
matt can you get me a link clubgp isnt working for me
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyMon Apr 07, 2008 6:12 pm
sure. here is the write up i used. i believe i found it on clubgp, but as you said it isnt working right now frown
http://mykidz.net/GTP/CrankPosSensor.shtml
best of luck
PostSubject: fuel pump question (link to a walbro)   CAR PROBLEMS - Page 2 EmptyThu Apr 10, 2008 5:49 pm
http://www.racetronix.com/RX-G7-FPKG.html
which one would work better for my car
http://www.racetronix.com/RX-F98-FPKG-2.html
any help would be great by tomorrow
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 9:04 am
RX-G7
You will also ned this for the venturi line.
http://www.zzperformance.com/grand_prix/products1.php?id=616&catid=113
If you don't you will have to keep the car above a quater tank.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 9:14 am
after he gets his RIVI running "guys i keep running outta gas WTF mate's?" neutral neutral neutral i can see it now lol lmfao
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 11:08 am
Oldsman 105- I didn't have to use the venturi kit from ZZP but I did have to swap out the canister from a '97-'00 GTP and adapt it for the stock Riviera top fuel pump assembly. Although this kit might save you that step.
Palmeroycorey- the first pump 75 should work for you. The second one is a different design for a F-body should not used in out cars.
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 12:08 pm
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 2:41 pm
Is there anything wrong with your OEM pump?
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 2:47 pm
yes its not pushing enough gas, when we tried to start it i only got 28 PSI so im going to upgrade so something that is stronger and is strong enough for my new motor
urbsnspices
urbsnspices
PostSubject: Re: CAR PROBLEMS   CAR PROBLEMS - Page 2 EmptyFri Apr 11, 2008 3:25 pm
I would avoid using any pump that requires the ZZP venturi setup! The zzp kit used, and most likely still does use tubing that is not rated for fuel immersion. The tubing may rot or rupture leaving you stranded. Intense sells a pump with a built in venturi system and uses the oem tubing.
If I were to do it again I would go new OEM with a hotwire kit, or get the Walbro Intense is selling.
I could be wrong but 28psi should be enough to start the car. Check for a clogged filter.
CAR PROBLEMS
» RZR Wheel Hub Problems?
» 3500 still has problems
» GPX 4000 Problems
» Transmission problems
» Weber alternator problems
