Name : Travis Age : 33 Location : Minnesconsin Joined : 2007-02-08Post Count : 5127 Merit : 10
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 11:05 am
NICE........ can't wait to see it running..
ewolfe0050 Aficionado
Name : Eric Location : Indianapolis, IN Joined : 2007-07-31Post Count : 1159 Merit : 27
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 1:29 pm
Glad you took that route. The Walbro pump shsould work just fine for you. I am still working on trying to find my photos for a brief write up should you have any questions.
palermocorey90 Expert
Name : Corey Age : 33 Location : Rome NY Joined : 2007-10-03Post Count : 2968 Merit : -24
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 6:02 pm
thanks Eric but im have help from one of the biggest 3800 builders help me. he has a blue dayton GTP his name is dave and he runs low 12s
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 8:30 pm
Good deal- is he around your neck of the woods? Paul at PRJ helped me out through mine.. very, very happy with my setup but I am sure there are other good options.
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 9:39 pm
if ur ever on 3800pro. im sure you have herd of Dave Pettinelli. yes he is in my neck of the woods, about 5 mins away so like the same tree LMAO
Name : Codith Age : 36 Location : Villa Park, IL Joined : 2007-02-08Post Count : 3671 Merit : 140
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 11:04 pm
Corey, I'm curious, did you try disconnecting the vacuum hose to the fuel pressure regulator and look at the pressure at idle? That would essentially give you extra pressure if your pump and fuel path is able to supply it, that is. It should go up a good bit. From there, take the gauge into the car with you so you can read it, put it in drive, hold the brake and give some gas. See how much the pressure drops at that point. It should remain above say 40psi with or without the vacuum hooked up to the reg. Having it unplugged just makes it a little easier to observe what the pump is doing since its eliminating the effects of the regulator.
Subject: Re: CAR PROBLEMS Sat Apr 12, 2008 11:44 pm
no i didnt do that im just replacing it all this way i know its not the fuel problem
Subject: engine problems still there Thu Apr 17, 2008 11:52 am
i replaced the fuel pump, as im sure you know the walbro 255 LPH. and im still having my fuel problems, even tho im doing an engine swap this summer i would like to be able to drive my S1. this way i have a car to drive while my motor is being built . i made a video maybe some one can help me out. any one that knows the 3800 and is in NY that can help me. please do so i will PM my address to you.
current parts replaced. head gaskets ,LIM gaskets, super charger gaskets, TB gasket,spark plugs, ignition wires, fuel filter, fuel pump, TP sensor,and a few other small things
Name : Matthew Age : 37 Location : Florida Joined : 2007-01-17Post Count : 4394 Merit : 101
Subject: Re: CAR PROBLEMS Thu Apr 17, 2008 6:20 pm
the SES light should be on while the key is ON. that doesnt mean there is/isnt a code. you wont know till you plug up a scanner. nice video, going Blair Witch style huh? walking around narrating, drop the camera, and then hear you scream in the background...and blood splatter across the blower. sorry i know that doesnt help you out
you say it has weak spark? if you pull out a plug after trying to crank it, is it wet with fuel? can you get it running with a can of starter fluid?
_________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily
Subject: Re: CAR PROBLEMS Thu Apr 17, 2008 7:40 pm
yes they normally are wet with fuel.
T Riley Guru
Subject: Re: CAR PROBLEMS Thu Apr 17, 2008 11:00 pm
RUN CAR RUN!
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8577 Merit : 180
Subject: Re: CAR PROBLEMS Tue Apr 29, 2008 9:00 pm
Hey Corey - when you gonna change the crank sensor? That is about the only thing you have not said you've done.
Name : Dave Age : 63 Location : In The AZ Oven Joined : 2007-01-17Post Count : 4502 Merit : 44
Subject: Re: CAR PROBLEMS Tue Apr 29, 2008 9:38 pm
97rivman Fanatic
Name : alex Age : 38 Location : Crete,IL Joined : 2007-06-09Post Count : 484 Merit : 2
Subject: Re: CAR PROBLEMS Wed Apr 30, 2008 2:03 am
have u replaced the regulator? I just read through the whole thing and didnt see it once.
