RhinoFLA Aficionado
| Subject: Squeaking Fri Jan 11, 2008 8:54 pm | |
| I mentioned a squeaking in my knock post in the engine/tranny section. I thought it was my rear brakes but the noise doesn't change when I brake.. it's just a constant squeaking that sounds somewhat like a bearing. I don't know much about tire components, but could it be a bearing in there somewhere? | |
| Subject: Re: Squeaking Sat Jan 12, 2008 3:52 pm | |
| front or rear? constant squeak? does the pitch change with speed? does it change or go away in turns? both sides or just one? paper or plastic? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: Squeaking Sat Jan 12, 2008 4:55 pm | |
| I can't seem to hear it when I drive past anything on the drivers side, I only hear it when the sound echoes off an object on the passenger side.. i'm thinking it's in the rear, but i'm not sure. it does incrase when speed changes, I haven't noticed it on turns though.. PAPER OF PLASTIC IS A TRICK QUESTION! Neither are environmentally friendly matt! I carry all my groceries.. | |
| Subject: Re: Squeaking Sat Jan 12, 2008 5:03 pm | |
| sounds like a brake pad warning squeal to me. Does the sound change when you touch the brakes? | |
RhinoFLA Aficionado
| Subject: Re: Squeaking Sat Jan 12, 2008 5:26 pm | |
| not at all. it's just a constant squeaking as I drive. It doesn't occur when i'm just sitting idling so i've ruled out pulleys/belts | |
| Subject: Re: Squeaking Sat Jan 12, 2008 5:56 pm | |
| which sounds just like a pad squeal. It is a little metal tab sticking off the brake pads. When the pads wear down the metal tab rubs on the rotor to make a squealing noise. It's like that on purpose. It only makes noise while the wheels are turning.
Sometimes when they just start to touch, the sound changes when you touch the brakes. Sometimes the sound is a steady constant whether you are on the brakes or not.
Check your pads... | |
RhinoFLA Aficionado
| Subject: Re: Squeaking Sat Jan 12, 2008 6:11 pm | |
