 Headwork?
5 posters
Headwork? Empty
PostSubject: Headwork?   Headwork? EmptySun Feb 11, 2007 9:49 pm
Do you guys think there would be any benefit to Porting a Polishing a set of heads. But still having the stock cam?
Headwork? Empty
PostSubject: Re: Headwork?   Headwork? EmptySun Feb 11, 2007 11:35 pm
Surely there would be a benefit if you knew what you were doing. Whether it would be worth the work/cost is the question.
Headwork? Empty
PostSubject: Re: Headwork?   Headwork? EmptyMon Feb 12, 2007 1:13 am
and thats my next question happy
Headwork? Empty
PostSubject: Re: Headwork?   Headwork? EmptyMon Feb 12, 2007 8:54 am
smile I would say not worth the cost until you have already done ported blower, big cam, small small pulley and you are outflowing the stock heads... but will you see some gain? Probably a little...
What's your mod list?
Headwork? Empty
PostSubject: Re: Headwork?   Headwork? EmptyMon Feb 12, 2007 10:25 am
look under his signature it has a link to his mod list
urbsnspices
urbsnspices
Headwork? Empty
PostSubject: Re: Headwork?   Headwork? EmptyMon Feb 12, 2007 5:08 pm
Look at it this way, if you ever do a cam, then you will have to take the heads off anyway. Basically I wouldnt do the heads unless you are doing a cam.
Sure you can get a cheap set of heads to play with. BUT to swap them in you will spend a lot of cash on gaskets. SC + Lower intake + Head gaskets+ Rocker bolts, to name a few.
Headwork? Empty
Headwork?
