| Is this person on here? Check his Riv! | |
+6mr.19982tone jimmyriv Jack the R Mr.Riviera palermocorey90 xxsupergman25xx 10 posters |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Is this person on here? Check his Riv! Fri Jan 11, 2008 10:38 pm | |
| http://www.cardomain.com/ride/2979368 | |
palermocorey90 Expert
| Subject: Re: Is this person on here? Check his Riv! Fri Jan 11, 2008 10:53 pm | |
| i have seen that car before, Syracuse is like 20 mins from me | |
| Subject: Re: Is this person on here? Check his Riv! Sat Jan 12, 2008 4:00 pm | |
| wow if he spent half the money on engine mods instead of the sound system it would be running low 13's, but each to his/her own i guess. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Is this person on here? Check his Riv! Sat Jan 12, 2008 4:15 pm | |
| Thanks xxsupergman25xx, I was thinking of painting my car that way but I don't like it so much now.
Did he bend the antenna over so it wouldn't retract? | |
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 13, 2008 9:29 am | |
| the car is on..therefor antenna up...and i would have no idea anyway...this guy commented my grill on cardomain and saw his | |
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 13, 2008 2:22 pm | |
| Doesn't the antenna extend straight up? | |
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 13, 2008 3:28 pm | |
| i dont think so but then again mine does go down , so im going to cut it out with a plasma cutter | |
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 13, 2008 5:49 pm | |
| You don't want it to retract? | |
jimmyriv Junkie
Name : James Age : 80 Location : Muskegon, Michigan Joined : 2007-03-16 Post Count : 781 Merit : 8
| Subject: Re: Is this person on here? Check his Riv! Mon Jan 14, 2008 9:49 am | |
| If your antenna isn't straight, there is some adjustment inside the driver side inner trunk panel. Mine wasn't straight when I got it and I was able to move it to almost vertical. If you can,t get it straight enough I think it can be modified by extending the strap a little. | |
| Subject: Re: Is this person on here? Check his Riv! Mon Jan 14, 2008 3:37 pm | |
| - Jack the R wrote:
- You don't want it to retract?
no im smoothing down the body | |
| Subject: Re: Is this person on here? Check his Riv! Mon Jan 14, 2008 8:51 pm | |
| You're going to remove the antenna? I've thought about doing that - it's not like radio is worth listening to. | |
| Subject: Re: Is this person on here? Check his Riv! Mon Jan 14, 2008 8:56 pm | |
| i want to take mine out too. when i installed my second head unit, i hooked up the wrong wire for the power ant. and never bothered taking the dash apart to fix it. i never listen to the radio, but i get pretty good reception even with it down. any way to just remove the motor and rod. then cap off the hole and hook up a flexible antenna inside the trunk? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
jimmyriv Junkie
| Subject: Re: Is this person on here? Check his Riv! Mon Jan 14, 2008 8:57 pm | |
| Who listens to their radio with cd's and subs amplified.???????.... | |
mr.19982tone Member
Name : john Age : 39 Location : syracuse ny Joined : 2008-01-14 Post Count : 52 Merit : 0
| Subject: posting pics Fri Jan 18, 2008 9:44 pm | |
| how do i post pics of the best riviera in the world..witch is mine.im a computer dumbass | |
| Subject: Re: Is this person on here? Check his Riv! Fri Jan 18, 2008 9:49 pm | |
| urs is far from the best there big guy i have seen it. but welcome. good to have another central NY member on hear.
ok to get pics on hear go to www.photobucket.com up load up pics and after there uploaded there will be a IMG code copy and paste that into ur post
**also you might want to post about yourself in the welcome section so we know who you are | |
| Subject: Re: Is this person on here? Check his Riv! Sat Jan 19, 2008 12:37 am | |
mr.19982tone Member
| Subject: https://s273.photobucket.com/albums/jj211/mr19982tone/ Sat Jan 19, 2008 1:18 pm | |
| https://s273.photobucket.com/albums/jj211/mr19982tone/ | |
mr.19982tone Member
| Subject: uummm Sat Jan 19, 2008 1:28 pm | |
| ok guess the pics are on there now....i think | |
| Subject: Re: Is this person on here? Check his Riv! Sat Jan 19, 2008 1:34 pm | |
Jason Aficionado
| Subject: Re: Is this person on here? Check his Riv! Sat Jan 19, 2008 2:20 pm | |
| Subject: Re: Is this person on here? Check his Riv! Sat Jan 19, 2008 8:10 pm | |
| nice paint job! good paint scheme that folows the lines of the rivi.....maybe ill do the same in the future.... | |
mr.19982tone Member
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 20, 2008 12:46 am | |
| j/k about the best in the world by the way a siver arrow tricked out with 6000 orig miles would be the best!! | |
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 20, 2008 1:00 am | |
| no a stock silver arrow u dont trick out a silver arrow. tricking out a silver arrow would be like "pimping" a ford escort its just not the right thing to do
LOL | |
Jason Aficionado
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 20, 2008 1:08 am | |
| I would mod a silver arrow if I had one | |
mr.19982tone Member
| Subject: Re: Is this person on here? Check his Riv! Sun Jan 20, 2008 1:19 am | |
| im just talking about rims,brakes,some beat but no cutting and a nice set of mufflers nothing major | |
| Subject: Re: Is this person on here? Check his Riv! | |
