 something wrong .... again
GothicVash
something wrong .... again Empty
PostSubject: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 11:48 am
ok now something else is wrong with my car it wont go into overdrive but it would a few weeks ago i got the idleing problem fixed when it was in idle it would shake more then normal i had a broken tensioner now the trany dose shift fine into everything just when i put the pedal all the way down for overdrive my car stutters really bad and dosent accellerat anymore im hopeing this isnt a trany prollem cuz there expencive but it seams like it is one oh yeah its a 95
PostSubject: Re: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 12:06 pm
Mine did the same thing last week and it turned out to be a split vacuum line from the front of the intake manifold.
PostSubject: Re: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 12:12 pm
How new are your spark plugs & wires?
GothicVash
PostSubject: Re: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 12:57 pm
plugs is new wires are not
PostSubject: Re: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 1:04 pm
If wires have close to 100k miles or more, I'd replace them with new. Once I thought my transmission had gone out, and wires was the only problem.
GothicVash
PostSubject: Re: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 1:19 pm
so that could be the wires and yeah its at 95 k right now
PostSubject: Re: something wrong .... again   something wrong .... again EmptyTue Jan 22, 2008 1:32 pm
Vacuum lines are easy to check and inexpensive to replace. Even if you fine the wires bad, I suggest getting a new vacuum kit. They are inexpensive.
» You Aussie Prosepectors are "doing it wrong"...
» I have smoke coming from under the flywheel, Have I wired It wrong?
» Goal celebration gone wrong
» The Wrong Mans
» What am I doing wrong...
