 Write-Up: Installing Intercooler (IC)
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Sun Feb 08, 2015 10:16 pm
Sorry I keep talking about this but, I have the opportunity to get what I would consider to be an incredible deal on a used full size intercooler setup. So, if I were to notch out the inner sheet metal on the hood, the core should fit without cradle spacers or anything? Also, would anyone be interested in my ssic setup and a gen v?
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Mon Feb 09, 2015 3:51 pm
GUYS HELP. It's the 2.25" core.
It's the full ic setup, a gen v, and the lim, and he wants $600. That seems almost so cheap that I should expect something to be broken. What do you guys think?
Merit : 49
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Mon Feb 09, 2015 3:59 pm
If you can afford it, jump on it. Ask the guy if you can return everything if there's something you don't like.
Merit : 126
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Mon Feb 09, 2015 7:02 pm
I'd probably jump on that. Just tell em you're prepared to buy as long as nothing wrong with it or whatever.
I haven't verified myself but you should be able to fit it with only cutting the good inner sheetmetal in a couple spots at worst. The front mount will be the interesting part
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Mon Feb 09, 2015 7:07 pm
Just get it over with - cut a hole in the hood and let the blower stick through. Air cooling!
Merit : 49
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Tue Feb 10, 2015 10:06 am
Tell him about the blower. The blower man!
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Tue Feb 10, 2015 6:32 pm
I told the dude PayPal is all ready to go. Just waiting on him to figure out how much shipping will be. If it weren't a DD, I probably would just cut a hole in the hood. That would make it a racecar.
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Wed Sep 28, 2016 8:29 am
Finally got my front mount installed over the weekend. Yes, I know I've had the phenolic core installed for years now...
Question for those that have done a fmhe, where did you wire up the pump? Want it on with key on and driver fender seems like best placement.
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Wed Sep 28, 2016 8:53 am
Buddy of mine has the lightening.
Merit : 126
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Fri Sep 30, 2016 2:58 pm
Holy crap I thought you already had yours all going this whole time!
For the pump I put mine in the passenger fender area (there's pics somewhere) with a relay right by it and wired the turn-on signal into the cabin where I have a switch to accessory power behind the radio. I Tapped into that for all sorts of added things. I like having the switch to be able to turn off the pump during PCM flashing and stuff like that. Don't forget a fuse - don't want a shorted pump to burn down yo whip
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Fri Sep 30, 2016 3:08 pm
Thanks for the reply.
Was hoping to run it to an existing wire so it would run so long as the key was on. Im afraid if i put it on a switch ill forget to turn it off and kill the battery lol .
Merit : 126
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Fri Sep 30, 2016 3:41 pm
When I did manuels car I connected to the icm switched feed. That worked fine
PostSubject: Re: Write-Up: Installing Intercooler (IC)   Tue Oct 25, 2016 9:03 am
https://drive.google.com/file/d/0B9EDGDpPO33IOEpEWWR1THJ2amM/view?usp=sharing
Quick video showing post intercooler install. Really opens up top end where i was seeing a few degrees of KR.
I ended up using a 12V relay and running the signal wire off the EGR harness since i dont have an EGR and it was hot with key on.
Page 8 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
