| EGR Valve Troubles | |
+25AA nvsteve chitown_riv98 charlieRobinson rivparadise DEMonte1997 turtleman rk0ehn LARRY70GS dboydakid setsuna57 Karma Andysdorm Mr.Riviera Abaddon L67 deekster_caddy albertj palermocorey90 TonySmooth89 shrek90 BillBoost37 dreww Jason 96RIVMANN 29 posters |
Andysdorm Aficionado
Name : Andrew Age : 39 Location : Worcester, MA Joined : 2007-01-17 Post Count : 1394 Merit : 6
| Subject: Re: EGR Valve Troubles Mon Nov 21, 2011 1:20 pm | |
| That's interesting. I was hoping to find a pic online to show people where my problem was. Oddly enough, my EGR is located up front kinda where you see the black latch in this newer engine pic above.
I still would like to put a lot of miles on it before I say goodbye. I may have to pull a Top Gear and donate my Riv in Louisiana.
| Subject: Re: EGR Valve Troubles Wed Mar 07, 2012 5:23 pm | |
| Finally some good news!
Today while out doing errands I stopped in at the local Advance for a price quote on a new EGR valve. Suprisingly it was less expensive than that awesome website for GM parts that was introduced to me from a member here.
Original Price from factory: $289.14 shopgmparts.com: $166.24
Advance Auto: $136.49
and the magic, for a limited time until March 10 they have a promotion for $15% off parts.
I ended up paying $116.xx so from $289.xx to $116.xx is kinda a big deal for me given the unemployment is all gone and still no job. Every savings opportunity counts.
It's defintely not a factory part but appears to be the same size/shape, has a lifetime warranty, and I can pick it up from the store tomorrow.
My car is by no means a collector car so any part that can at least get it to functioning condition is A-OK in my book.
This post is to help those who may have been in a similar situation as me waiting for some sort of a price brake on an expensive part. | |
| Subject: Re: EGR Valve Troubles Wed Mar 07, 2012 10:44 pm | |
| The awesome GM parts website is only if you need a GM part. That's only for certain things, for most parts I would turn to the aftermarket. But stay away from the cheapest parts (Valuecraft from Autozone, for example) if you can. I like Advance.
(If you want to try to get my commercial Advance discount send me a PM) | |
| Subject: Re: EGR Valve Troubles Thu Mar 08, 2012 8:52 am | |
| No, it's not Valuecraft. I should be OK.
I may take you up on that discount offer too if it's not a hassle. | |
| Subject: Re: EGR Valve Troubles Tue Mar 20, 2012 5:36 pm | |
| Right before I went on vacation for the week my girlfriend's dad helped me install the new EGR valve. And it made all the difference. Power is back and runs smooth at idle. but the light is still on. At highway speeds, when cruise control is set, it does feel unusual; not instantaneously notceable but "slippy". also I noticed the techometer seemed 'stuck' at points and would not change when I gave it a bit of gas and let off the gas. This was only on the highway and when I got off and braked it went down. So for now it's good'nuff. | |
chitown_riv98 Fanatic
Name : Ruben Age : 42 Location : Illinois Joined : 2008-03-10 Post Count : 399 Merit : 4
| Subject: Re: EGR Valve Troubles Tue Jun 19, 2012 1:42 am | |
| What happened to this project dude? I'm pondering gettin a new EGR
| Subject: Re: EGR Valve Troubles Tue Jun 19, 2012 3:44 pm | |
So for now it's good'nuff. You either have to reset the light or wait some 25+ drive cycles before it will turn itself off. Better yet get a scanner and read what the code actually is - might be a new one. | |
nvsteve Member
Name : Steve Location : Minden NV Joined : 2011-10-06 Post Count : 53 Merit : 3
| Subject: Re: EGR Valve Troubles Wed Sep 12, 2012 6:25 pm | |
| How does one go about cleaning an EGR valve?
Thanks | |
Karma Aficionado
| Subject: Re: EGR Valve Troubles Thu Sep 13, 2012 9:57 am | |
| I've had mine off when it was throwing a code, and tried to clean it out, but it never really made a difference. And it was hard to see what to clean without damaging its solonoid. The only true fix was to buy another one. (400$ are in Canada, 120$ shipped if you use rock auto. guess which one i did.) _________________ | |
charlieRobinson Expert
| Subject: Re: EGR Valve Troubles Fri Mar 15, 2013 5:29 pm | |
| Halfway through my drive home from work and my SES light appeared. I've got P1404. P1404 Exhaust Gas Recirculation System Valve 2.
Any ideas what it could be? Looks like some EGR BS. I'm gonna start researching now.\ Found this: http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=18&t=6857 | |
| Subject: Re: EGR Valve Troubles Fri Mar 15, 2013 5:50 pm | |
| Probably stuck open. If you take off the EGR, you'll see what's clogging it. Or, keep driving and it could go away on it's own. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: temp Fri Mar 15, 2013 10:04 pm | |
| Yep, you got it AA. I scanned it when I went out this evening. getting 0.8V at idle and then I saw it go up to like 4-5V under acceleration. Parked, turned it off, turned it back on and the SES light was gone!!!
| Subject: Re: EGR Valve Troubles Mon Apr 01, 2013 9:26 pm | |
| - nvsteve wrote:
- How does one go about cleaning an EGR valve?
Thanks there are EGR valve cleaning fluids available from autoparts stores. ...also by the way the problem usually is carbon buildup that has condensed and clogged passages in the intake manifold. As hot as the EGR runs it's not *that* susceptible to blocking although it does snot up from time to time. Either need to remove the intake manifold and dip/clean it or use spray cleaners and pipe cleaners/wire brushes/coat hangers to scrape out the carbon buildup. Kind of reminds me, for some reason, of a dentist removing plaque from teeth. | |
werdstrave Enthusiast
Name : Drew Joined : 2011-09-12 Post Count : 153 Merit : 1
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 1:13 pm | |
| Hey guys,
I'm trying to trouble shoot this right now. Andrew and Noah, if you or anyone else could chime in that would be awesome. I had not run my riv in a week and when I started it up it hick-uped and felt like it was going to stall. It has done this in the past but with a little gas I was able to get up and going (clue?). However, for the past week I've been driving around with it doing this and it won't resolve. I have little power and the engine sputters but won't stall. It will drive, the engine just feels like it's getting choked (hesitates, won't go when I give it gas, etc). I got it checked out at the shop and they said it threw an EGR valve stuck open code (OBDI code 41). I declined the $500 service and began trouble shooting the EGR valve based on internet research.
Removing the valve I can depress in the pintle up and down with no problem. Does that mean it's not faulty? I'm going to check the continuity across the pins and wiggle the harness to see if it's electrical. I've replaced the warn gasket, it did nothing.
Other than that, I was thinking of doing the old soapy water trick on the pipes to see if there is a leak on any of them.
My question to Andrew and Noah and anyone else with experience is, did you guys have similar symptoms? If so did you try cleaning and trouble shooting the EGR valve before replacing? Did replacing solve your problem? Just wanted to know before I dropped the cash on the new valve as I am not sure the valve is faulty or if it's something else. Let me know. Going to trouble shoot now.
Drew | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 1:17 pm | |
| If you can physically move the pintle up/down, the EGR valve is broken. The PCM commands that valve open and closed in steps based on throttle position. It's physically connected to "motor" inside of it. | |
llamalor2112 Junkie
Name : Evan Age : 31 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 852 Merit : 13
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 2:15 pm | |
| ^really broken? That is interesting. I recall a buddies car throwing an egr code once and he depressed the pintle and cleaned the heck out of the thing. Just felt like a retention spring underneath. Got it cleaned so it would slide smooth rather than sticking, put it back on and car ran fine and never threw the code again | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 2:34 pm | |
| I wouldnt think a broken EGR would cause that kind of a driveability issue, but im no expert since ive had mine off for years now. Sounds more like a ignition problem to me.
For what its worth though, i have a EGR at home in very good condition if you end up in need of one.
Matt _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
llamalor2112 Junkie
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 2:36 pm | |
| EGR can and will cause those problems as that is exactly what was going on with my friends sl4 when it happened. Just for reassurance. | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 2:54 pm | |
| Thanks for the comments guys. I did the soapy water test on the piping to the EGR valve. No leaks. The mechanic said that it was "stuck open". I'm just trying to make sure I shouldn't look at anything else before buying a new valve since I haven't determined whether it is broken or not. Scott said it was if I can move the pintle. I've seen online that it can be cleaned and re installed by moving the pintle so I'm doing a little internet research now. Any other suggestions on determining if the valve is broken? I feel like there are mixed opinions on the pintle being able to be moved or not.
P.S Thank Matt, will let you know. | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 2:55 pm | |
| - llamalor2112 wrote:
- ^really broken? That is interesting. I recall a buddies car throwing an egr code once and he depressed the pintle and cleaned the heck out of the thing. Just felt like a retention spring underneath. Got it cleaned so it would slide smooth rather than sticking, put it back on and car ran fine and never threw the code again
Maybe it's the new(er) style I'm thinking of. The older ones are electro-magnetic and vary position based on current (Amps). Either way, you can't test that thing without a scan tool to command the steps to watch it move. It very well may be failed electrically (internally). If the PCM tries to move the pintle, and it gets full current feedback, the circuit is considered open. Yes, if you completely open an EGR valve, the car will run like testes. It throws off the MAF and fuel tables because of the unwanted incoming air to the engine. If the PCM wants the EGR closed, and it's not, the engine will act like it has a vacuum leak. | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 5:24 pm | |
| Just got the AZ EGR valve. Installed it. Still the same issue. Thoughts? | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 5:49 pm | |
| - werdstrave wrote:
- Just got the AZ EGR valve. Installed it. Still the same issue. Thoughts?
Did you clear the code after the install? | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 6:00 pm | |
| Ummm...someone might want to verify this for me, but isn't code 41 a Cam Sensor Code? | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 6:23 pm | |
| I don't have a code scanner and posted on another thread to see if anyone had the list for obd1 95 riviera. Please post here if anyone has info on this. | |
| Subject: Re: EGR Valve Troubles Tue Mar 04, 2014 9:03 pm | |
| Alright. Reset the computer by disconnecting the battery with the new EGR valve on. Hooked the battery back up and turned on the engine and still the same problem. I guess I can rule out the EGR valve as being the problem which is bogus because the shop just ran away with my $100 diag fee and told me that's what needed to be replaced. "Code 41 EGR Malfunction"..... apparently that's what it is?
Anyways, I can smell a slight hint of exhaust in the engine bay. Not sure if that's a hint at something but can't quite tell where it's coming from. Could a hole somewhere in the manifold throw an EGR malfunction code? If they are telling me the truth and that's what it is? | |
| Subject: Re: EGR Valve Troubles | |
