 Found a lost switch
2 posters
cragmor
Found a lost switch Empty
PostSubject: Found a lost switch   Found a lost switch EmptyTue Feb 13, 2007 1:27 pm
I was plugging in my scanner this afternoon, and I noticed a switch hanging down under the dash. I do not know where this goes, and it has a red top. It is a momentary push button switch. I will try to get a picture of it.
Anyone know what it might be for?
Merit : 251
PostSubject: Re: Found a lost switch   Found a lost switch EmptyTue Feb 13, 2007 1:29 pm
Valet switch from past alarm system?
cragmor
PostSubject: Re: Found a lost switch   Found a lost switch EmptyTue Feb 13, 2007 1:34 pm
I was thinking something along those lines. Perhaps something aftermarket. A quick glance did not show me much, but it appears to be part of stock wiring.
Merit : 251
PostSubject: Re: Found a lost switch   Found a lost switch EmptyTue Feb 13, 2007 1:38 pm
Most likely aftermarket unless you see a hole in your dash.
cragmor
PostSubject: Re: Found a lost switch   Found a lost switch EmptyTue Feb 13, 2007 1:46 pm
My first thought was that it might be for the traction control. The button does not do anything on the dash, so maybe it came loose and fell. But that is a long way to fall, and i am not sure it could get up that high. Plus I doubt GM would use a setup like that, the switch would be completely integrated.
Found a lost switch
» Have the left rear wheel speed sensor open or shorted dealer codes 1234 123
» Rear adjustment links and tie rods for Riviera
» My mom found oil in my car's radiator.
» FAQ: Rims, Wheels that Look Good on the Riv
» FOUND someone with the tuner
