 Fuel Rails
jamie
lyonsperformance
BillBoost37
Turbocharged400sbc
urbsnspices
17 posters
Go to page : 1, 2, 3  Next
Fuel Rails - Page 2 Empty
PostSubject: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jan 30, 2008 7:31 pm
Who was the one that designed the billet fuel rails?? ZZP has the new style IC available in two weeks and the stock rails pose clearance issues.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jan 30, 2008 8:03 pm
it was Turbocharged400sbc
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyTue Jun 24, 2008 9:20 pm
I just received these from ZZP and I'm pretty impressed. I don't really need fuel rails, but this was only $135 and I am installing new injectors, plus I have two stock rails + rockers I can return to ZZP for a $70 core.
The powder-coating looks very well done. I just hope they fit:
Fuel Rails - Page 2 FuelRAIL1
Fuel Rails - Page 2 FuelRAIL2
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 12:35 pm
nice, I plan on getting the same rails when I do my injectors.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:16 pm
AA is lying he is going intercooled right??????? wink
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:20 pm
Not any time soon. If I can get my car to run KR free again, I'll be happy for a while. It's nice to have that option, though.
I think it might be possible to remove the blower without taking the rails off. Maybe there's a ported blower in the future.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:35 pm
These are supposed to be a direct swap from stock? I might want to go that route whenever I get to the injectors.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:37 pm
I will soon find out. They are actually modified from stock rails. My concern is connecting the lines, but I want to use braided stainless anyway.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:41 pm
*New version works with all intercoolers or without an intercooler. No need to remove the blower to install or remove the fuel rails.
**Not recommended for cars with TOG headers as the crossover gets too close to the fuel line. Pacesetters are OK though.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:58 pm
I can guarantee that setup will not work with an IC... at least the full IC. You might be able to get away with it on a short stack IC. You might be able to extend the SS lines to fit around the SC. The GTPs have a little more hood clearance than our rivs...
BillBoost37
Merit : 26
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 1:59 pm
Where in the world do the rails pictured get close to the cross over? Looks like ZZP missed updating that part, IIRC their last set of rails had a hose under the TB.
I could see issues trying to get the fuel line to stretch across the top of the TB to the front connection and could also see issues with the rear line pushing back into the firewall and kinking. That's the reason I went to braided after installing PRJ rails. No kinking was a big weight off my mind.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyWed Jun 25, 2008 2:53 pm
Dunno, I just copied/pasted from ZZP site.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyThu Jun 26, 2008 1:47 am
cus the rail is held on by 4 bolts rolleyes pretty tough to remove razz
BillBoost37
Merit : 26
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyThu Jun 26, 2008 6:59 am
It's more about disturbing the FI o-rings and possibly creating a vacuum leak or the need to replace the rings again. While the rings are low cost, if you are running stock injectors there is a chance to break them each tme you try to pull a ring. The bottom piece that holds them on is brittle.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyThu Jun 26, 2008 9:25 am
Yeah, I chipped one the first time I removed my injectors. I don't like taking them out if I don't need to.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyThu Jun 26, 2008 1:19 pm
i chipped 2 or 3 myself evil
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyFri Jul 04, 2008 10:07 am
After installing the ZZP rails, I wasn't too impressed with the fit. I had to bend the front tube in order to get around the BBV, and same with the rear because of the STB bar. Also, the connector hose is made for use with an IC, so it's too long. I can understand that, though.
It's a better set-up than before, but I need to replace the now odd-looking plastic fuel lines with some braided SS. The way the stock lines are bent now, they look pretty strange.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyFri Jul 04, 2008 3:28 pm
So these wont work on a full intercooler setup? If not, I see no point in buying them.
does that mean the only other option is the twice as expensive rails like Bill has on his car?
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyFri Jul 04, 2008 4:08 pm
This setup will not work on an IC setup. They have injector spacers available but I would watch for leaks (if it does leak hot engine + fuel is not good). The only way to do it right is to get their full logs, Intense logs, or PRJ logs. I chose the latter. The Riv has very little clearance with a full IC so spacers may not fit either...if you want to take a chance they wont leak.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptySat Jul 05, 2008 5:27 pm
I don't see why they can't work with an IC. Both ZZP and W-Body sell these modified rails exactly for this purpose. I can remove my blower while leaving these rails on - why couldn't I squeeze and IC in there?
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyMon Jul 07, 2008 12:11 pm
this is what I was thinking. Does wolf know something we don't? Or did he actually try it himself and they didn't work?
wolf, got a link for those PRJ rails?
BillBoost37
Merit : 26
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyMon Jul 07, 2008 1:58 pm
http://www.prjperformance.com/
I think Eric is getting at the hose going over the charger and how Paul had to cut his hood for a little more clearance on top. (at least I think I remember reading that) The PRJ rails have nothing over the top when an intercooler is on the engine, so space on top of the charger is saved.
Do it the way I did guys... keep your eyes open for someone selling them for say $100 or so off the original price.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyMon Jul 07, 2008 3:16 pm
The hose is only about 3/8" dia, and fits between the heat sink fins of the blower. If you are really concerned about clearance, get a longer hose and go around the blower.
PostSubject: Re: Fuel Rails   Fuel Rails - Page 2 EmptyMon Jul 07, 2008 4:13 pm
Exactly.. I had to cut the hood I a couple spots for a little for spacing. The Rivs hood dosen't give you the clearance like the GTPs. If you have to squish the upper line against the hood... resulting in chaffing.... resulting in a hole in the fuel line... resulting in fire frown
Youo could possibly go around the blower but from the snout side. Don't rest it by the headers!
lyonsperformance
lyonsperformance
PostSubject: Fuel Rails   Fuel Rails - Page 2 EmptyWed Aug 13, 2008 9:56 am
any benifit to buying upgraded fuel rails? If you only have a slightly modified motor?
if so i was thinking of buying these more for a cleaner "built motor" look.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D14131&N=700+4294924744+4294908256+4294908237+4294925239+115&autoview=sku
tell me what ya think! scratch
Fuel Rails
» Aeromotive 3.8L Fuel Rails
» Frozen Fuel Rails. Brrrrrrr!
» Mothers metal polish vs. fuel rails
» fuel line leak. need to disable fuel pump. Fuse or relay?
» Fuel Line/Fuel Rail connector leak
