| Fuel Rails | |
+13jamie Chicken lyonsperformance T Riley dreww ewolfe0050 palermocorey90 BillBoost37 Turbocharged400sbc 1998 Riv AA urbsnspices RhinoFLA 17 posters |
BillBoost37 Junkie
| Subject: Re: Fuel Rails Wed Jun 25, 2008 1:59 pm | |
| - 1998 Riv wrote:
- *New version works with all intercoolers or without an intercooler. No need to remove the blower to install or remove the fuel rails.
**Not recommended for cars with TOG headers as the crossover gets too close to the fuel line. Pacesetters are OK though. Where in the world do the rails pictured get close to the cross over? Looks like ZZP missed updating that part, IIRC their last set of rails had a hose under the TB. I could see issues trying to get the fuel line to stretch across the top of the TB to the front connection and could also see issues with the rear line pushing back into the firewall and kinking. That's the reason I went to braided after installing PRJ rails. No kinking was a big weight off my mind. | |
| Subject: Re: Fuel Rails Wed Jun 25, 2008 2:53 pm | |
| Dunno, I just copied/pasted from ZZP site. | |
T Riley Guru
| Subject: Re: Fuel Rails Thu Jun 26, 2008 1:47 am | |
I think it might be possible to remove the blower without taking the rails off. Maybe there's a ported blower in the future. cus the rail is held on by 4 bolts pretty tough to remove | |
BillBoost37 Junkie
| Subject: Re: Fuel Rails Thu Jun 26, 2008 9:25 am | |
| - Quote :
- The bottom piece that holds them on is brittle.
Yeah, I chipped one the first time I removed my injectors. I don't like taking them out if I don't need to. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Re: Fuel Rails Thu Jun 26, 2008 1:19 pm | |
- Quote :
Yeah, I chipped one the first time I removed my injectors. I don't like taking them out if I don't need to. i chipped 2 or 3 myself | |
| Subject: Re: Fuel Rails Fri Jul 04, 2008 10:07 am | |
| After installing the ZZP rails, I wasn't too impressed with the fit. I had to bend the front tube in order to get around the BBV, and same with the rear because of the STB bar. Also, the connector hose is made for use with an IC, so it's too long. I can understand that, though.
It's a better set-up than before, but I need to replace the now odd-looking plastic fuel lines with some braided SS. The way the stock lines are bent now, they look pretty strange. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Re: Fuel Rails Fri Jul 04, 2008 3:28 pm | |
| So these wont work on a full intercooler setup? If not, I see no point in buying them.
does that mean the only other option is the twice as expensive rails like Bill has on his car? | |
ewolfe0050 Aficionado
| Subject: Re: Fuel Rails Fri Jul 04, 2008 4:08 pm | |
| This setup will not work on an IC setup. They have injector spacers available but I would watch for leaks (if it does leak hot engine + fuel is not good). The only way to do it right is to get their full logs, Intense logs, or PRJ logs. I chose the latter. The Riv has very little clearance with a full IC so spacers may not fit either...if you want to take a chance they wont leak. | |
| Subject: Re: Fuel Rails Sat Jul 05, 2008 5:27 pm | |
| I don't see why they can't work with an IC. Both ZZP and W-Body sell these modified rails exactly for this purpose. I can remove my blower while leaving these rails on - why couldn't I squeeze and IC in there? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Re: Fuel Rails Mon Jul 07, 2008 12:11 pm | |
- I don't see why they can't work with an IC. Both ZZP and W-Body sell these modified rails exactly for this purpose. I can remove my blower while leaving these rails on - why couldn't I squeeze and IC in there?
this is what I was thinking. Does wolf know something we don't? Or did he actually try it himself and they didn't work? wolf, got a link for those PRJ rails? | |
BillBoost37 Junkie
| Subject: Re: Fuel Rails Mon Jul 07, 2008 1:58 pm | |
| http://www.prjperformance.com/
I think Eric is getting at the hose going over the charger and how Paul had to cut his hood for a little more clearance on top. (at least I think I remember reading that) The PRJ rails have nothing over the top when an intercooler is on the engine, so space on top of the charger is saved.
Do it the way I did guys... keep your eyes open for someone selling them for say $100 or so off the original price. | |
| Subject: Re: Fuel Rails Mon Jul 07, 2008 3:16 pm | |
| The hose is only about 3/8" dia, and fits between the heat sink fins of the blower. If you are really concerned about clearance, get a longer hose and go around the blower. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Fuel Rails Mon Jul 07, 2008 4:13 pm | |
| - Quote :
- I think Eric is getting at the hose going over the charger and how Paul had to cut his hood for a little more clearance on top.
Exactly.. I had to cut the hood I a couple spots for a little for spacing. The Rivs hood dosen't give you the clearance like the GTPs. If you have to squish the upper line against the hood... resulting in chaffing.... resulting in a hole in the fuel line... resulting in fire Youo could possibly go around the blower but from the snout side. Don't rest it by the headers! | |
lyonsperformance Enthusiast
Name : Michael Age : 40 Location : Buffalo N.Y. Joined : 2008-08-02 Post Count : 178 Merit : 0
| Subject: Fuel Rails Wed Aug 13, 2008 9:56 am | |
| any benifit to buying upgraded fuel rails? If you only have a slightly modified motor? if so i was thinking of buying these more for a cleaner "built motor" look. http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D14131&N=700+4294924744+4294908256+4294908237+4294925239+115&autoview=sku tell me what ya think! | |
| Subject: Re: Fuel Rails Wed Aug 13, 2008 10:01 am | |
| Nice find. Wish I'd seen those a month ago! I think thems some affordable fuel rails.
The benefit is that the fuel doesn't cross over the blower, so in theory stays slightly cooler, but that's only hypothetical. They look good, though! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Chicken Aficionado
Name : Mark Age : 57 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
| Subject: Re: Fuel Rails Wed Aug 13, 2008 10:15 am | |
| On a scale of 1 - 10, whats the difficulty in installing these yourself? | |
| Subject: Re: Fuel Rails Wed Aug 13, 2008 10:19 am | |
BillBoost37 Junkie
| Subject: Re: Fuel Rails Tue Aug 19, 2008 1:21 pm | |
| After seeing where your hoses turn to metal, it should be easier than on the bonne. Hardest part of making the fuel lines was getting the braid inside the ends. A little finesse and it's a snap. I had it nearly perfected by the time I was done. | |
jamie Fanatic
Name : Jamie Age : 36 Location : Truro, NS Joined : 2008-06-17 Post Count : 283 Merit : 1
| Subject: Re: Fuel Rails Tue Aug 19, 2008 2:56 pm | |
| - Turbocharged400sbc wrote:
Dude, looks like you just made good use of a real fancy pipe. | |
captshiner Junkie
Name : Andrew Age : 37 Location : Cincinnati, OH Joined : 2008-07-23 Post Count : 756 Merit : -1
| Subject: Re: Fuel Rails Tue Aug 19, 2008 3:14 pm | |
| Is that a recent pic? I was wondering because it's like 80+degrees here in OH and I'm assuming the "Il" in your info. means Illinois. And you are dressed pretty warm. | |
dreww Junkie
| Subject: Re: Fuel Rails Fri Aug 29, 2008 1:20 am | |
- Nice find. Wish I'd seen those a month ago! I think thems some affordable fuel rails.
The benefit is that the fuel doesn't cross over the blower, so in theory stays slightly cooler, but that's only hypothetical. They look good, though! so you think these will work fine for our rivs? I might order some this weekend and maybe some 42.5's to go in them. | |
| Subject: Re: Fuel Rails Fri Aug 29, 2008 9:15 am | |
| I don't know, but it appears that way. I'm guessing if they bolt on, they'll work. Only fear is that something would be in the way. Try it! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Re: Fuel Rails Thu Sep 04, 2008 2:40 am | |
- I don't know, but it appears that way. I'm guessing if they bolt on, they'll work. Only fear is that something would be in the way. Try it!
I just ordered the injectors instead. I might try these rails out, but I still need to nit pick and buy all the other parts to complete a "fuel rail kit". I will probably end up just forking up $400+ for the PRJ kit. | |
| Subject: Re: Fuel Rails Wed Sep 10, 2008 5:19 pm | |
| ewolfe - Does anyone make dress up valve covers for the L67? I thought ZZP did but I didn't see them on their site. I'm new to this fuel injection stuff. Looking at BillBoost37's thread, it appears the fuel rails aren't included in his parts list like I initially thought they were. What brand do you recommend, what are the issues with fuel rails? How can I tell if a fitting comes with an o-ring or not? AA - O.K. if you think the valve cover gaskets are good I'm going to leave them for now. If the temporary setup is the best you've found I can also worry about that later. Now that I think of it all this stuff will have to come apart to do cam and intercooler, maybe I should just build up a big pile of performance parts and have it all done at once (somebody got a new client today ) Would you say o-rings are a pressing priority? Either way, let's keep talking about it so I know what to get. | |
| Subject: Re: Fuel Rails | |
| Fuel Rails | |
